Grandson spilt milk on my mitsubishi HD tv how do I get it cleaned if it got into the screen
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Do not use any cleaner with chemicals in it---try a lens cloth with just a little pressure and slightly damp with distilled water---you can damage the screen very easily as most are anti-glare coated like a camera lens.
Posted on Nov 04, 2012
5 Suggested Answers
  • 9 Answers
SOURCE: grandson spit milk on the screen and wiped it
Look from hex screws along the top and sides of the screen in the back of the tv. From there unscrew them all and carefully pull the frame out then there should be a second set of hex screws. that will remove the protecting cover.
Posted on Sep 18, 2009
  • 15 Answers
SOURCE: my grandson has squirted milk in different areas
this is what i do in the workshop warm water in a bowl with a little washing up liquid & a clean soft cloth ring it out then go over spots u my need to do the whole screen as one area is now very clean . do this very softly .
Posted on Apr 11, 2010
  • 362 Answers
SOURCE: i have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Posted on Nov 17, 2010
hardrocko
  • 1476 Answers
SOURCE: I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 15, 2010
I have a Phillips net tv. My grandson spilled milk down the front of it now the remote control will not work with it. I have a feeling that it broke the sensor in the front of the tv. Is there a way I can...
The liquid might have entered into the front panel control board; and micro-switches. Milk won't evaporate like water. The front panel of the TV should be taken out to clean it. Contact any service technician, as this work can only be done by opening the TV.
Nov 07, 2014 | Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
I spilt milk on my samsung laptop I shut the power off and wondering what is the best way to dry it
Most likely when the laptop dries out the milk residue will stop the keyboard keys from working properly. Depending upon how much milk has been spilt the milk may have penetrated to the motherboard and caused more damage.
Place the laptop in a warm area for several days.
If the laptop boots up properly but the some of keyboard keys don't work then a replacement keyboard may fix your problem.
Keyboard replacement maybe available from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jun 24, 2012 | Computers & Internet
I have a mitsubishi 65"
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
Jul 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-52525 52 in. Rear Projection HDTV Television: My grandson sprayed water on the screen and it got...
Only if it is the protective front screen that the issue is with. the only way to take the protective screen out is to open the tv. A service tech can do this for you however it will not be a cheap fix.
May 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My grandson has squirted milk in different areas of the screen it is dryed up what is the best thing to do to try and clean these spots off some 3to 4 inces wide looks kind of black
Apr 11, 2010 | Hitachi 51F500 51" Rear Projection...
Grandson spit milk on the screen and wiped it around now screen looks like there is milk in between screen 57H84C toshiba. how to clean it out?
Sep 18, 2009 | Toshiba Televison & Video
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Spillage
If you hurry and get some flux off and take the tv apart and clean all the PCB's with the flux off, provided the set still works, then you can possibly save it
Aug 29, 2006 | Goodmans W280NS Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
