Question about Homedics Humidifiers
Homedics ultrasonic humidifier will not turn on
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
How to clean homed is humidifier
Hello, Mary -
This is the link to the PDF document with the Instruction Manual for the Homedics Humidifier model UHE-CM45:
https://www.homedics.com/media/documents/homedics/instructionbooks/UHE-CM45_IB.pdf
Cleaning instructions start on Page 9 of the instructions.
You can download and save the instructions as well as print them, if you wish.
Best wishes.
Jan 08, 2018 | Humidifiers
Need directions for homedic ultasonic humidifier
http://www.homedics.com/cool-mist-ultrasonic-humidifier-3574.html
Dec 08, 2017 | Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
What is the box with lightning bolt inside? turn on humidifier and just the orange light above this comes on but humidifier not working?
I looked at the Owners Manual for your humidifier online, but could not locate what you described.
However, it is manufactured by Homedics and you can contact their Customer Service Dept @
800-466-3342 Mon - Fri, 8:30a - 5pm ET for help in solving your problem.
Mar 07, 2011 | Walgreens Cool Mist Ultrasonic 2 Gallon...
Humidifiers Logo
65 people viewed this question
Top Homedics Humidifiers Experts
Paul Carew
Dennis
Are you a Homedics Humidifier Expert? Answer questions, earn points and help others
