HOT AND WARM WATER LIGHT FLASHING - Washing Machines
  • leonardgid
    leonardgid Nov 05, 2012
    Hello Richard , thank you for replying, these are all the details, Simpson 22S750N,PNC913041047/00 ,SN031532266. This is two years old, i also checked/cleaned the hoses and filters, also tested spin and drain and rinse and spin, the pump worked but not the spin , this morning after a good six hours switched off it worked , but after opening and closing the lid a few times, the 5 1second beep followed by the blinking hot,warm ,cold lights continues as before..
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
My swan sw2010w washer takes on a little water then stops and lights start flashing red.
it could be a water valve fault. is it set to cold only or hot only or warm?
if warm try cold only or hot only to see if it is a valve fault.
Jun 15, 2013 | Washing Machines
Received washing machine with no instructions,favourite program show preference for warm water wash,when I go to use cold wash it fills very slowly and then beeps show warm water light flashing I need to...
You MAY have a faulty cold valve (Not unusual) Or low water pressure. If the machine will fill ok on 'hot' but has a problem on 'cold' then you probably have a faulty 'cold' valve.
Do not change wires to 'hot' valve, as there is a difference..
Good luck....Nomess
Aug 04, 2010 | Fisher and Paykel Fisher & Paykel Washer
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Load the circuit
Hi
It means you need to prime the lines. Push the button for water, then open the knob on the right. When water starts to flow the red light should disappear, and start to warm up. If the red light doesn't disappear, you may have a restriction in the flow meter, or intake line.
Nov 08, 2009 | Saeco Incanto Classic Espresso Machine
Does not warm up
HI
If you don't have any other lights on, it could be 1 of 2 things. Your boiler is bad or your power board is bad. Can you get steam or hot water?
Oct 25, 2009 | Solis Palazzo Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
97 saturn sl2 temp light flashing and low coolant light flashing what could be the problem ? coolant is full and the heat works.
If the temp gauge is reading normal, the lights are flashing, and the coolant level is full, the level sensor in the coolant bottle is the problem. I'm a service consultant for a Saturn dealer and I've run across this many times.
Apr 17, 2009 | 1997 Saturn SL
Temperature light on and stop light flashing on and off
hi comman fault on these vans is the temp sender which is located on the right hand side of the engine it has 2 wires on a connector that plug onto it they are quite cheap about £8-£10 and i think its a 19mm spanner you will need just undo and refit with new one. regards
Feb 11, 2009 | 2007 Fiat 124
Temp lights changing before full wash
your hot water supply might not be getting to the machine.
check the filters in the hot water supply hose.
If the waters not hot enough the hot water light will flash,or you can go into Options adjustment,in your user manual,then adjust you water temperature, its is easy.
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
