Question about Kenmore Side by Side Refrigerator
Some items in fridge frozen
Some things on different shelves have frozen.... not everything has... but its hit or miss what freezes
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
  • 4 more comments
  • Andrea Barnett Nov 04, 2012
    Model number is 596.5565 2500 I have the settings set on 2 for freezer and 1 for the fridge and things are still frozen but only some things. The higher the number the colder the temp...I have contemplated unplugging for a couple hours but I don't know if that will do it. The water dispenser is still flowing so it's not completely frozen but the water is much colder than normal.
  • Richard Roth
    Richard Roth Nov 04, 2012
    You will need to check to see if the damper in the frig side is closing and opening. Here is the part should you find it bad. http://click.linksynergy.com/fs-bin/clic...
    The damper is currently closed I will check it again in a few min... I think it does open and close though.
  • Richard Roth
    OK,keep me posted.
  • Andrea Barnett Nov 05, 2012
    opens and closes... I cleaned the coils under the fridge and it seems to be doing much better
  • Richard Roth
    Richard Roth Nov 05, 2012
    Keep me posted.
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Posted on Jul 02, 2008
erpaalai
  • 999 Answers
SOURCE: 2 weeks ago the ice box was not cooling.. We
Could be a defrost problem. When the coils get froze over it quits coling. Turning it off will temporarily defrost a portion of the coils and it works for awhile. Check behind the freezer wall for frost buildup. If it is, you will have to determine if the timer, heater or termination thermostat is the culprit.
Eric
Posted on Dec 25, 2009
richroth
  • 9472 Answers
SOURCE: Kenmore side by side fridge- bottom drawer of
The crisper can freeze when air leaks around the base of the duct assembly. To prevent this, the air tower will need to be removed (see picture). Disconnect power to the unit first. All the shelves and drawers will need to be removed, to access the tower. With the air tower out, now run a bead of silicone on the floor where the tower sits. Now replace the duct on top of the sealant to make a tight seal and prevent the air leakage.
Posted on Sep 20, 2011
Why would food in the refrigerator side freeze?
probably your Damper unit! In the fridge section is a hit and miss type vent using a motor to open and close via PCB temp sensor!
Oct 07, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
We just purchased this model, and the items in our refridgerator keep freezing, including the milk in the door. We have turned down the setting to 2 and it keeps occuring, is this common? Mostly things...
I've actually ran inti this problem alot. its just a design flaw. the objects that are freezing are close to the direct flow of cold air coming from the freezer into the fresh food compartment. adjusting the temperature will result in the same condition. The only thing you can do is rearrange products closest to the air duct. You may even gave to rearrange the shelves. Just ran into this same problem yesterday when i was dispatched to a customers home. Its just a stupid flaw in the design of the fridge.
Feb 08, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
