Question about Hitachi CP-X345 Multimedia Projector
Can LED bulbs be used as its lamp alternative ? if so, how much power would be used ?
  • aleeasmar
    aleeasmar Jan 20, 2013
    May there be some confusion in my query and its understanding that I could not find proper solution...I repeat that as the Hitachi CP-X345 Multimedia Projector's lamp emits 2000 lumens, now if I need to use LED bulbs with an emission of 200 lumens only, then how much watt power LED would be required ?...(Additional info...this LED bulb arrangement would not use the built-In power supply and would be powered by some other source to be added further)
    New Friend:
    Problem Solver:
  • 9 Answers
No direct replacement as far as I know, wish there was. there is a starting circuit to fire up and run and monitor the bulb which is specific to the mercury bulbs, you would have to change more than just the bulb.
Posted on Jan 18, 2013
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
SHEERLED LED Bulbs SPOTLIGHT IN UK GU10 LED Lights IN UK
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
Dec 01, 2011 | Cars & Trucks
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Jan 08, 2009 | Sony KDS-60A3000 60" HDTV
Viewsonic PJ550 lamp
Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
Nov 27, 2008 | ViewSonic PJ550 Multimedia Projector
JVC HD-ILA Projection TV
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
• It may be a malfunction that the fan is locked or the temperature has increased.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
The LAMP LED
continues blinking
• It may be a malfunction of the internal electrical circuits
Feb 16, 2008 | Televison & Video
Open Questions:
Hitachi CP-X345 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
