"are all honeywell 8 "fan limit switches interchangeable
I am trying to replace my fan limit switch from a goodman
SOURCE: honeywell manual fan switch broken
The fan limit switch is basically like a thermostat. When the plenum heats up to a certain degree it turns on the fan to start heating your house, and turns off when the fan off when the plenum gets around 80-90 degrees so that you’re not pumping cold air in to house. It also acts as a safety switch if the fan does not come on the plenum will get way to hot so this fan limit will kick the furnace off before that happens. As far as that little white button it should always be on auto you can try to use needle nose pliers to get it back into the auto position, or if you have the broken piece you can try to glue it back on. The white button goes in and out it does not turn or anything just make sure you turn the power off first and if u can’t fix it replace.
Posted on Nov 17, 2008
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
FunnyPlumber
  • 43 Answers
SOURCE: where can I purchase parts?
Try Orange County Appliance Parts in Garden Grove, CA. http://www.ocapsupply.com/
Posted on Jun 25, 2009
  • 232 Answers
SOURCE: I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Posted on Nov 06, 2009
  • 185 Answers
SOURCE: The fan starts and then the flame ignites but goes out
Did you clean the sensor with a piece of sand paper? Then wipe it with a dollar bill. The bill has a fire proof like chemical on it. Rubbing it on the sensor will coat it and keep it cean longer. If this dont work let me know
Posted on Mar 21, 2010
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
Goodman gas pack unit indoor fan stays on all the time
Problem may be with the high limit switch located above the burner assembly with two wires to flat rectangular looking plate. Jumper the two wires and see if the fan quit's running. If so replace high limit switch.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
I have a 30 year old fedders furnace and the furnace fan runs continuously. I was told by several people that the problem was probably a defective fan limit switch. But because its an older furnace with...
The switch will be the silver/gray box just above the burner in the supply plenum...
There really is nothing you can do to fix that if it is bad... the switch runs off of a bimetal spring and that has just plum worn out...
The main thing you need to check is the insertion depth of the bimetal spring...then you can buy a replacement at any HVAC supply house...
Chances are that what you have is a Honeywell product and you can download anything you need from the honeywell site...
I tell you how to do it in this tip...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 03, 2010 | Heating & Cooling
Goodman A18-8 electronic furnance and AC troubleshooting.
Check the unit for a high temperature limit switch, usually a round bimetal disc or a square plate that
would insert into the unit. If the switch is bad, it opens up and the fan will run no matter what. Complete the circuit with jumper wire, if fan shuts off
replace switch
Jun 12, 2010 | Goodman GMS90703BXA Heater
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Older Goodman gas package unit combustion and circulating fans
There is a limit switch tripped somewhere. it is either the main limit in the firewall orthe limit switch on the small fan (inducer) that is tripped some of these are manual reset try pushing the button in and see if that stops it.
Feb 03, 2009 | Goodman CLQ36AR49 Air Conditioner
Honeywell manual fan switch broken
Oct 13, 2008 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
