Question about Hitachi 43FDX01B TV
Hitachi 46f500 resistors - Hitachi 43FDX01B TV
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Google this----the burnt one will look bigger----most are actually 1/2 watt and none that burn are over 1 watt. If 46 one of the two chips for convergence got it.
Posted on Nov 04, 2012
46F500 white smoke
First unplug the unit until problem is found---I would look inside for burnt parts like resistors in the convergence circuit which is the most common issue this set has.
They may be discolored or brown in the middle and not actually charred.
Locate what burned and you will locate the area where the problem is, many resistors in that area are protection, if a short they destroy themselves very quickly ....
If you were having any issue before or at the point it started smoking where picture looked odd or even 3d it will be in the convergence circuit.
Not exact but something like this--the two black chips and resistors in front of them.
Dec 11, 2012 | Hitachi 46F500 46" Rear Projection...
Tv does not turn own, red power button just flickers
Replace your STKs they are big black ICs will have part # on them STK392-110 if 110s use 150s better ICs also you need to CK small ohm resistors rk42 rk48 rk50 rk52 rk56 rk58 rk62.I will have to get back to you after i find correct value of resistors.
Sep 18, 2009 | Hitachi 46F500 46" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 and there is a blue curved bar
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Hitachi 46F500 46" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46f500 screen messed up after welding on same circuit
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Jun 15, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi HDTV Model 46F500
You have two bad convergence integrated circuits and possibly an open resistor or two in the supply.
Mar 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 43FDX01B TV Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
