Question about Whirlpool Duet GHW9150P Front Load Washer
F1E2 error code
My washer is giving me an F1E2 error code. It'll turn on, but it won't start. Can you please help me figure the problem out & how much I'm looking at spending on repairs.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F1 - E1 EEPROM checksum error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Here is the part to order.
Posted on Nov 04, 2012
jsrock516
  • 5911 Answers
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Posted on Apr 29, 2007
SOURCE: the problem is i'm getting
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F20” error code.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
courtesy:Jsrock516
regards iversh
Posted on Sep 21, 2009
ZJLimited
  • 17970 Answers
SOURCE: error code FL flashes and
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
Posted on May 20, 2011
TheMobilian
  • 8220 Answers
SOURCE: We have a duet washer
F-71 user interface heartbeat failure, com failure between touch pad and central control.
You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
Service manual for duet with repair photos
Posted on Jun 26, 2011
KevinWhite
  • 1902 Answers
SOURCE: washer won't start.....F70 code appeared It's
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Duet model WF w 93515 w 00 code F1e2
An F1E2 error code is a motor control unit error. The main control has detected that the motor controller is not doing something right. Sound funny, I agree but this is what the manufacture tells me. I assume the washer has been working fine and then this pops up? The checks for this is to find the motor controller at the bottom of unit and locate the wiring to it. Unplug washer and then unplug each wiring harness and plug back in. Test. If problem still exists, then locate the main control at top and do the same. Unplug wires, and test again. If still issue, the its a 50/50 guess, between motor controller and main board. I don't like this code because I can only go so far then I have to take a guess. Sorry.
Nov 27, 2015 | Washing Machines
F1e2 error code
F1E2 error code usually refers to something with the control board. I do not have info before me, but believe the board has to be replaced.
Package info somewhere inside your stove will give you the explanation of that error code.
It does not hurt to unplug the stove for fifteen minutes/turn it on again and see what the error code is, if any.
Oct 19, 2013 | Whirlpool SF367 Gas Kitchen Range
99 gmc 3500 tool box truck won't start. it just quit. turns over but won't start
You'll have to figure out if it is a fuel or ignition problem to proceed.
Check for spark at the plugs, and fuel pressure at the injectors.
You might want to check the computer for trouble codes too.
Jul 19, 2012 | Cars & Trucks
Wont turn over
If it cranks it turns over.
If it won't start, you'll have to figure out if it is fuel or ignition related to continue.
Check the injectors for fuel spray (TBI) and the plugs for spark.
Did you check the computer for trouble codes ?
Jul 17, 2012 | 1993 Chevrolet K1500
Just won't start! fuel pump ok, filter ok, psi ok, turns over just won.t start
You'll have to figure out if it is a fuel or ignition problem.
Is the check engine light on ? Have you checked for trouble codes ?
It could be a relay, the ignition module, coil, or a list of other things.
Even the fuel pump.
If this is a vortec V6 it takes at least 60psi to cover the injectors.
Jul 03, 2012 | 1997 GMC Jimmy
2005 Hyundai accent won't start. it turns over but is not starting.
Check and see if you are getting spark to the plugs first.
Also re-check the computer for codes and see how many are back.
Trouble codes are suggestions, not solid instructions.
Jun 28, 2012 | 2005 Hyundai Accent
EPIC MODEL MHWZ600TW00...no display, no power up. Have tested outlet and electricity is fine. Would love to have an error code to help, however, without display I am lost.
diagnostic test -- the washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test. 1) close the door 2) select any one key (except PAUSE/CANCEL) and follow the steps below, using the same key): a) press/hold 4 sec b) release for 4 sec c) press/hold 4 sec d) release for 4 sec e) press/hold 4 sec 3) upon release, all console LED lights will turn on for 5 sec 4) if there are any failure codes, they will be displayed in the Estimated Time Remaining display. NOTE: This program recalls the most recent failure code first. 1) press the same key to advance to the next failure code. (if the console doesn't change then the same failure code was stored multiple times.) 2) if there aren't any more failure codes all the lights on the console will turn on for 5 sec 3) next the washer begins the diagnostic test 4) to cancel out of service mode press PAUSE/CANCEL. this exits you out of the program. **Hope this helps; got it off the manual for service technicians.... most likely you'll get an F28 code (Serial Communication Error -- the communication between the central control unit (CCU) and the motor control unit (MCU) cannot be sent correctly). We are having this problem now and just replaced the CCU to a tune of around $300 ($120-$150 for CCU part & repairman labor cost + call/diagnostic cost)... it still is not working so I guess we'll replace the MCU next. If that doesn't work then we'll have to get a new washer that's not a frontload. What a nightmare; wished we had done research on frontloaders. Good luck!
Oct 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a kemore elite he 3t front load washer it won't drain and its giving me a F02 error message. what does this mean? Help!
it's a long drain error code,most likely the pump is blocked with all kinds of good stuff,coins, screws,and who knows what else,vac out all the water with a shop vac, and next time open the door,look around the opening where you put the clothes into the washer and you'll see a tag with the model and serial numbers,just need the model number,remove the bottom panel,look at the pump,if the center part can be removed,turn it slowly counter clockwise until the water starts to leak out and stop and vac up the water as it leaks out,do this until it's empty and then remove the center catch piece of the pump and clean it out,stick your finger in the pump and make sure nothing is stuck in the impellar,also check the rubber boot part of the hose,sometimes stuff is still in there,if the center of the pump doesn't come out,pull off the hoses to the pump and check them for junk in them and check the pump,reconnect the hoses,fill with some water and put in a spin cycle,if the water still doesn't drain out most likely you'll have to change out the pump.
Aug 16, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
735 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
