Question about Technics SC-DV290 System
TECHNICS SC-CH550 STEREO SYSTEM
System has started turning itself off when volume is turned up on both cd and tuner. This does not happen as soon as you increase volume but 1/2 minutes later. It continues to run ok if volume is kept down.
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Posted on Mar 15, 2009
User operating instructions for a Technics SA-CH550 tuner amp
Try Googling (technics)(SA-CH550)(manual) without parens.
Apr 27, 2017 | Technics Audio Players & Recorders
Have just encountered an older (abt 15 years) technics stereo system with components such as turntable, cd player, cassette recorder, tuner, equalizer and amp. i've the rca's all hooked up and it's...
Doesn't matter what order the 3.5mm are wired up in. As long as one connects to another in a daisy chain, data will jump from one to the other to give remote operation or auto source changing
AW
Sep 04, 2010 | Technics SC-DV290 System
Technics SC-770 am/fm tuner turns on by itself when in the stand by mode
Check to see that there isn't an alarm function selected, as the reason it's turning on by itself.
Apr 14, 2010 | Technics SCEH790 CD Shelf System
How can i put my tv threw my stereo i have yellow white and red in the back of tv and in the back of the stereo i have 2 white 2 red and 2 black pls can you help me
Since we're most concerned with the stereo sound, disregard colors and read the silkscreened legends for the connectors.
However you would be better to get your TV-related audio from the cable box in the same way. TV electronics is on the lo-fi end of the quality spectrum. And its own volume control may affect the output. If the TV has a setting to make the output FIXED, select it so you can turn the TV volume down and let the real speakers do the audio job.
Whichever you choose...
Connect Audio L and R Out from the TV to any convenient input (AUX?) on the Technics.
Apr 10, 2010 | Technics SC-EH780 CD Shelf System
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Sc-ch550.any idea at all y it is switching itself off when ya turn up the volume loud?
It could be number of thing such as defective speaker, fan or fan control circuit, power amp fault etc. You can try to disconnect speakers one at a time and see if any of them causing a problem.
Dec 28, 2009 | Technics SC-DV290 System
Can you connect the sl-ch550 to the computer
yes. depending on pc type.
on a laptop, connect a 3.5mm jack to headphone socket and rca to aux in.
on a desk top connect 3.5mm jack to audio out(green) to rca to aux in
May 02, 2009 | Technics SC-DV290 System
My stereo turns off by itself and the indication F61 appears
1st case dry solder connection in power board and amp bpard ,resolder and unit will be working o.k
Oct 28, 2007 | Technics SC-EH780 CD Shelf System
Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Mar 01, 2007 | Technics ST-GT350 Tuner
Technics SC-DV290 System Logo
1,156 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
