Question about Delta 28-060 14'' Band Saw Blade 93-1/2'' x 1/2'', 14 Teeth per Inch
What is the best band saw blade for cutting metal
    Problem Solver:
  • 7 Answers
You want one with fine teeth
Posted on Jun 30, 2014
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
  • 87 Answers
SOURCE: need blades for a black and decker band saw 7
You can det it @ www.grainger.com. hope this helps
Posted on Oct 03, 2009
  • 4088 Answers
SOURCE: problems with my band saw bs100
Look for any gouges in the metal surface that have metal projecting above the milled surface. Also, file or grind away any sharp edges along the miter gauge track. If the cut surface is very irregular, the blade may have overly coarse teeth, or the blade guide rollers may not be holding the blade firmly allowing the blade to wander while cutting. Hope this helps.
Posted on Oct 24, 2009
RonPark
  • 855 Answers
SOURCE: My blade on my Delta BS100 Shopmaster 9 inch bench
Check and see if one of the guides is out of alignment or if the blade is worn. Either one can cause the problem since you already checked the tension and guides. If the guides are worn they won't hold the blade true.
Posted on Dec 30, 2009
  • 42 Answers
SOURCE: I'm looking for a table top band saw that will cut
i have a great company for you to contact to find the perfect blade for your needs. go to www.doall.com and click on the doall sawing tab and find the customer support phone number. call them during business hours and you can get at blade tech on the phone that will ask you a few questions to what saw you have and what your cutting and they can put you on the perfect blade. i use them for a bandsaw we use at work, we manufacture awnings and signs. i get all my bandsaw blades from Doall
Posted on Dec 24, 2010
Is there a steel cutting blade for genesis band saw model # GBS900
I got my band saw blades on sawblade.com. They customized blades and they offer different types of metal cutting blades.
Dec 03, 2014 | Blade Saws
Length of band saw for 7 1/2 black and decker band saw blade
I get my band saw blades on www.sawblade.com . I cut both wood and metal. I'm using their Carbon and Bi metal blades. Give them a call.
Aug 12, 2014 | Saws
Mbs45 blade undercuts out of square, twist in 2x2 1/8" tubing
I believe Black bull band saw is a Taiwan imported saw. They are even cheaper to HF band saws. This band saw have so many issues; make sure you align the guides, tune it up and use good bi metal band saw blades. I suggest you use the Haltbar 601 bi metal blade. I'm using Haltbar and I'm getting really nice cut.
Jun 18, 2014 | Buffalo Tools Black Bull Metal Cutting...
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
How do you line the blade on a shopfox m1014 it wont cut stright
You should check your manual for correct blade tracking adjustment. Place the guides properly. You should use a fine
blade as well. I have 7x12 band saw and I am using Haltbar band saw blade on it. I got it on sawblade.com . The blades
are really good.
Mar 27, 2013 | Shop Fox Metal Cutting Band Saw 7in. x...
How do i change blade
What is your bandsaw? I have metal and wood cutting band saw. I just follow the procedures in the manual. I am using different Haltbar saw blades,well, actually it would depend on what stock I'm gonna cut. Try reading this blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ . Hope that helps.
Feb 09, 2013 | Saws
Hey , I read this blog and it helped me a lot in choosing the correct saw blade in my cutting application. This might help you .
http://bandsawblog.com/choosing-the-right-blade-for-your-cutting-application/
Try checking this site : sawblade.com . :) Hope this will help you .
jack
Nov 07, 2012 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Problems with my band saw bs100
Jun 27, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Delta 28-060 14'' Band Saw Blade 93-1/2'' x 1/2'', 14 Teeth per Inch Logo
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
