Question about Logitech Computers & Internet
Logitech wireless mouse M205 - double clicks
When I delete one email, two disappear. The mouse is double clicking the delete.
SOURCE: G7 Wireless Mouse keep double clicking
Same Problem, use canned air to clean it. bash the button a few times. seems to help for a while. Dont bash it to hard or you'll break it. love the mouse but this is a crappy issue within 3 months of use. in a clean environment.
Posted on Jun 19, 2008
antiochpc
  • 1314 Answers
SOURCE: Logitech Cordless Mouse clicks too fast!
Try going into control panel, mouse, and set a longer delay for the double click.
Thanks and please take a moment to rate as FixYa. Thank you.
Posted on Jul 23, 2008
SOURCE: Logitech G7 cordless laser mouse - erratic action
Acting on advice from another FixYa string, we blew out the mouse and dock several times with canned air. It performed slightly better, but then as we continued to use the mouse it suddenly cleared and is working almost 100% now.
From reading earlier strings, I'm wondering why Logitech (in its product material received on purchase) doesn't recommend this as periodic maintenance for the mouse?
Posted on Dec 09, 2008
SOURCE: Logitech MX610 problem.
Hi, I have had the same problem with a Logitech Cordless Desktop setup. The mouse and keyboard had been used in an office environment for about two years, then the mouse would double click unexpectedly, would not hold items when trying to drag them and the right click would sometimes fail to work ...then sometimes it would work perfectly. I tried all the other suggested cures such as cleaning out the inside of the mouse, new batteries and reinstalling the driver which did not prove to be effective. A good clean improved things for a couple of days but the symptoms returned. At this point, I dismantled the mouse and resoldered some suspicious looking joints on the circuit board inside, especially those attaching the microswitches for the mouse buttons. Since then, none of the problems have recurred. I presume that repeated pressure on the switches over time had cracked the solder joints which caused the mouse to behave erratically. You could try this, but dont get the joints too hot or you will damage the switches or other sensitive components. Simon.
Posted on Feb 18, 2009
  • 497 Answers
SOURCE: double click on single clicking the left mouse
Try changing the "Double-Click speed.
2. Check for the Folder option.
Good Luck!!!!!!!!!!!!
Posted on Oct 20, 2009
When I left click it will double click
There is a possibility that on the windows operating system (control panel/ mouse) the option to double click with a single touch is turned on. I doubt that it is a problem related to the wireless system itself.
Sep 16, 2010 | Logitech Cordless Mouse
I am having trouble with my computer mouse. It is not clicking properly to highlight or will double click when I've only single clicked. Any solutions?
Check mouse settings in control panel. There is some options for double click speed and many other options check once . If double click speed is high then system behaves like this. try to change
Jun 30, 2010 | Logitech Wireless Optical Mouse...
My logitech mouse started to behave as is I double click when i mean to single-click
http://forums.logitech.com/t5/Mice-Hardware/G7-Wireless-Left-click-inputs-a-double-click/m-p/265663
in short: take it apart, or return it
May 26, 2010 | Logitech 9311570403 Mouse
My laser logitech bluetooth mouse won't connect to the laptop again
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Mouse
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth Mouse will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
M205 Logitech wirelessmouse works in my laptop,
Perhaps your laptop can receive the signal from your wireless mouse (by design) whereas your desktop cannot. Your desktop may need an expansion card to communicate with wireless devices, such as a mouse or other such device.
Nov 22, 2009 | Logitech Cordless Mouse
My mouse double clicks when I on click it once. In Outlook this means that alot of the time I am deleting 2 emails at a time. How do I fix this
Click tools on the windows tab then click folder options and then general tab there u can enable or disable the "single click opening proprety" of your mouse
Hope ur problem is solved
Thank U and please rate my solution
Oct 22, 2009 | Logitech Cordless Mouse
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
Mouse inconsistent
Other than checking with the manufacturer for updated drivers or known issues - or attempting to roll-back the driver if a new one has been installed recently, I can't think of anything, seems to be a sticking button or otherwise faulty mouse.
Jan 05, 2009 | Computers & Internet
The wireless mouse Double clicks on its own
go into the control panel under mouse and make sure your settings are set to single click insted of double click.
Nov 28, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
