Question about Sony CDX-CA750X CD Player
No display Hi My car fuse recently blew (which controls live feed to my player). However when I changed the fuse the player now wont light up. I know I have power because I can eject a CD and the reset button causes the player to make a whirring noise Any suggestions? thanks! Brett
    New Friend:
  • 57 Answers
Check wires make sure they are not grounded meter them
Posted on Jan 10, 2009
2 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: My car fuse recently blew
Check your Ground wire on the Wiring Harness for the Stereo. If good Disconnect the Power and Ground for 5 Minutes then Reconnect. See what we have got then. Let me Know!
Posted on Jan 04, 2009
My buddy has a 03 trailblazer he blew a fuse tiring to wire in some lights with his dome light so we replaced the fuse everything works good but the dome wont turn on when u open the doors and when u lock...
sounds like you blew more than one fuse.
check the live feed to the dome light, then check the earth return through the door switch, make sure it switches. if no earth return you must check wiring and switch. if no live, go back to fuse boxes.
cheers
Roger
Apr 21, 2014 | Cars & Trucks
I have a 2009 volkswagon jetta diesel my battery was bad so my son put his truck battery in it and hooked it up backwards now the power steering light is on and no power steering also alternator light is...
Hi, first thing to do and if you know location of the fuse box take light tester and test each fuse may you find some fuses blew. change theme first. if you change the fuses and the the problem for each item you describe still on that mean damage went to the items you say.
Dec 14, 2013 | Cars & Trucks
Obd scanner says no link
Chances are there is a blown fuse for the computer.
Is the check engine light on when you turn the key on ?
Jul 07, 2012 | 2000 Oldsmobile Intrigue
I have a 87 jeep comanche. auto. transfered to 4x4. my dash light wont work, i believe its a dead short because i raised the fuse number and it still blew. my question is, were would be the most likel
When say "dash light" I'm assuming you mean the nighttime illumination for instruments like the speedometer for example. If your truck has a stand-alone digital clock (not part of the radio) that has a feed wire from the instrument panel lights for it to dim at night, otherwise it'd be too bright. That could be a source of a short. The radio also makes use of the dash illumination as well, making the digital display darken at night and lighting the radio's controls and face plate at night, another source of a short in this circuit. Do not ever increase fuse ratings when replacing a fuse, that defeats the safety purpose of the proper fuse being able to blow, opening the circuit which prevents wires overheating and potentially catching fire. You don't want to go there. If you have recently installed another radio the wiring may be wrong. This happened a LOT on Pontiac Firebird's and TransAm's. People often wrongly assumed all black wires are ground and ended up grounding the dash illumination input. This blew the dash light fuse and made the retracting headlight doors stay up.
Jan 01, 2012 | 1987 Jeep Comanche
Wont turn on
Hi.
If it does not turn on at all, then there is something wrong in the wiring at the back of the unit. Double check wiring. Eventually use a volt-meter to check if there is 12V in the power leads. This units also have a fuse at the back. Replace the fuse. If the fuse blew, that means that there was a contact or an incorrect wiring.
Regards.
May 29, 2010 | Farenheit DVD-61 Car DVD Player
No power to white rogers thermostat
Either you blew the fuse on the air handler control board or you burnt out the air handler transformer.
The thing that blew the fuse is probably the contactor in the condenser unit. You will need to check out out cause of the outage before replacing the fuse or transformer.
heatman101
Apr 08, 2010 | Carrier 38CKC036 Air Conditioner
04 Chev Epica, will not start, no 4 ways no turn signals, no pwr mirrors, windows or door locks? Checked fuses, possible computer problem?
I had a similar problem recently with my Epica. During extremely cold weather I tried to use the windscreen washers which were frozen. This blew a fuse within the interior fuse box which controls the wipers, indicators etc. This also activated the flashing red security light on the display. The vehicle was still running but when I truned off the engine it refused to start again. Required to change the fuse (which from recollection is the 3rd down on the right - 10amp) before it would work again. Eventually blew again so replaced it with a 15amp fuse and been working fine ever since....
Jan 28, 2010 | 2004 Chevrolet Impala
My car fuse recently blew (which controls live feed to my player). However when I changed the fuse the player now wont light up. I know I have power because I can eject a CD and the reset button causes the...
Jan 04, 2009 | Sony CDX-CA750X CD Player
Broken cigerette lighter Golf GTI
you might check the fuses under the dash on the drivers side
Jan 02, 2009 | 2005 Volkswagen GTI
Sony CDX-CA750X CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
