Question about Makita G6100R 5800 Watt Generator
Hey guys, I have a mikita g6100 generator, it has run great for years, now when it starts on one pull, but after 20 seconds it chokes it's self out, can't figure out why, any help
2 Suggested Answers
  • 148 Answers
SOURCE: I have not used or started my generator in 3
Its absolutely the gas. Get all the old gas you can out of it and fill with fresh gas along with the recommended amount of conditioner such as Seafoam.
Posted on Feb 01, 2011
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
Mower starts and runs but has no power acts like its flooding it burns a lot more gas can barley pull it self
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Jul 26, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I own a 5000 watt generators the problem is generator starts with choke on however as soon as i start closing the choke generator shuts down, any ideal on how to correct
Get a can of carburetor cleaner. Drain the gas. Mix small quantity of fresh gas & carb cleaner about 50/50. Run a little through (it might not start, but crank it enough to get some solution through the carb.) If it runs, that's great, run about half of your solution then turn it off for an hour. Then run the rest through. If it won't start, then after the hour add a bit of fresh gas to make the remaining solution about 90% gas and run this through By the way, running the carb cleaner through the air intake will not fix this problem, because the gumming of gas is in the fuel line, float valve, needle valve - not in the air stream. Running carb cleaner through the air intake is useful if the throttle is sticking.. Good luck, Vote if you found this helpful, Al K
Jul 07, 2011 | Craftsman Electrical Supplies
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Instuctions on how to start mcculloch generator 1800 w
I have one.. great little unit.. very reliable..
I am a wannabee diy guy.. so good luck
1 assuming sparkplug is good / in / /newish??
Fuel needs to be filled.. I suggest premium only (less residue if it sits for long.)
fill oil.. top up..
d/c electric plugs
then
togle ignition switch to on
turn fuel cap to on
turn fuel switch (sw) to on
move choke to start if engine is cold start.
pull starter cord ..
good luck
ps.. I have learned to run engine dry of fuel after use. turn off fuel (sw).. this empties carb.. You may have to pull starter cord a few times with next start to bring the fuel down..
Sep 24, 2010 | McCulloch 2000W Inverter Digital...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Makita G6100R 5800 Watt Generator Logo
171 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
