I am looking for parts to a dayton 6Z098F wet dry vacuum
I am looking for a new impeller and housing
bozcro
  • 867 Answers
SOURCE: wet dry vacuums and shampooing rugs
they do ok, but a dedicated wet/steam cleaner does better
Posted on Sep 02, 2009
messstat
  • 365 Answers
SOURCE: I need a manual for dayton wet/dry vac, 4YE65
Contact "Grainger" by Googling the name...wonderful company that practically invented Dayton
Posted on Jan 02, 2010
  • 18 Answers
SOURCE: manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
Here is the user guide for model 1672 in either English or Spanish: http://www.bissell.com/searchresults.aspx?searchtext=1672&mode=userguides
Posted on May 25, 2010
SOURCE: My Rainbow vacuum is spitting water out through
It isn't a wet vac. You shouldn't be vacuuming up water with it.
Posted on Aug 09, 2011
small6363
  • 18424 Answers
SOURCE: Shop Vac 84M200 Wet/Dry Vacuum does it blow?
This video will show you.
http://youtu.be/-gCukdig57I
Posted on Oct 02, 2012
How do I fit a new pump to a ppw55
New pump wet ends have an impeller inside the housing and the impeller is threaded onto the shaft of the motor.
the four bolts go all the way through the motor and thread into the four little fingers on the wet end to hold it onto the motor.
Rod
US Parts Center
May 02, 2013 | Pool & Spa
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Can not get the Smartmix rotary switch to line up
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fsd5
May 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
We have a 1VHG3 and it keeps blowing,what is meant
The average life 5,000 means that the average life of the motor is rated at 5,000 hours of use.
Apr 16, 2010 | Dayton 4TB89 Industrial Wet/Dry Hang Up...
Not working after vacuuming water.
Your wet/dry vac came with 2 filters.
Paper for dust and dirt and Foam for wet/dry use.
If you left the paper filter on and tried to vacuum a wet surface, you most likely shredded your paper filter and clogged the outlet vent above your water shut-off float.
You should always use a filter to prevent clogging of the cyclonic impeller blades next to the motor. When extracting water or moisture you will need to use the Foam filter to prevent water from collecting in your fan blade area which then creeps to the motor eventually causing it to seize up.
Mar 15, 2010 | Craftsman 17776 Canister Wet/Dry Vacuum
Dec 28, 2009 | Vacuums
Rainbow SE (1991)
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Mar 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
