Question about Whirlpool Washing Machines
Fault code f 54 - Whirlpool Washing Machines
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F54 = Motor Control Overcurrent
F then 54 flashes when the machine/motor control detects high current for the motor module.
Does basket turn freely? If not, determine cause of friction.
Posted on Nov 04, 2012
What does codes 54 and 55 mean on my 2001 freightliner columbia 60 series detroit
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
May 19, 2015 | Cars & Trucks
2004 Honda CBR 125 R code 54
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://cbrforum.com/forum/other-models-125-250-400-66/cbr125r-2010-fault-code-54-a-156083
Honda Motorcycles Fault Codes Motorcycle Manuals PDF
Honda CBR125R Owner Manual service
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR125RW Owner Manual
Jan 14, 2014 | 2004 Honda CBR 125 R
What this cdes maen36/46/53/54
code 36 air switch solenoid circuit non turbo or wastegate solenoid circuit on turbocharged models.
code 46 battery voltage too high. code 53 module internal problem SMEC SBEC failure internal engine controller fault condition detected. code 54 problem with the distributor synchronizer circuit.
Jul 15, 2013 | 1991 Chrysler LeBaron
Check code 54 yamaha r6
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/282921-help-error-code-54-a.html
Yamaha Fault Codes motorcycle manuals
2007 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 02, 2012 | 2007 Yamaha YZF-R6
Honda cbr 125 fault code 54
Engine died with MIL fault code 54
Jun 27, 2012 | 2004 Honda CBR 125 R
1990 ford mustang lx 5.0L Code 54 How do i fix this
Fault Code 54
Description: No fuel injector sync pickup signal during engine rotation
Power loss light: On
Limp-in mode: Logic module will guess at injector timing
Possible Causes:
Bad connection or wiring - Check the wiring and connections between the hall effect sensor (located underneath the distributer cap) and the logic module. Check the continuity of the two 3 conductor cables coming out of the sensor--these are prone to fatiguing and breaking inside the insulation where they exit the sensor if the cables are not properly tied down. You may be able to resolder them. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Hall effect sensor failure - Check the two, flat 3 conductor cables coming out of the sensor. These often fatigue where they exit from the sensor. Upon replacing the sensor, make sure the cables are clipped or tied to the distributor cap shroud (or elsewhere) so they do not swing around.
Diagnostic Method
Trigger Parameters
- Engine cranking or running (signal coming from ignition reference sensor)
- No signal from the fuel injector sync pickup sensor
Results If Component Fails
Fault code 54 is stored. The engine will stall and will not start.
Good luck.
Apr 22, 2011 | 1990 Ford Mustang
Scania 114G 340 is not running after EDC warnings, error codes 53 and 54 can some one help me out.
the fault codes 53-54 is problem in cylender 3and4 unit injectores but that is not the main cause to make the engine is not starting check the overflow valve and the fuel pump or another fault code in the control unit
May 30, 2010 | Isuzu VehiCROSS Cars & Trucks
No spark at king lead, computer says codes 12, 54 and 55 1997 dodge grand caravan
this is what your check engine light was telling you. code 12 battery input was disconnected within the last 50 key-on cycles. code 54 no camshaft signal detected during engine cranking. code 55 completion of fault code display on check engine lite. hope this will help you!! note: camshaft sensor is located in distributor on 3.0liter engine and on a 3.3liter and 3.8 liter engines its located next to the thermostat housing.
Apr 20, 2010 | 1997 Dodge Grand Caravan
Engine codes 54 1991sunbird 3.1
I think this code is defined as follows:
Fuel pump circuit fault or Mixture Control (M/C) solenoid fault or Electronic Control Module (ECM) fault/EGR solenoid #2 failure
Check your fuel pump relay as well - this could be the fault in the fuel pump circuit.
Hope this helps, Sherwin
Apr 18, 2009 | 1991 Pontiac Sunbird
Washing Machines Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
