Question about Motorola Mobility RAZR V3c Cellular Phone
Which is the on button for the Razor?
My Blackjack died and I am using my old phone. I can't find out which is the on button for a silver Razor
    Sergeant:
  • 290 Answers
The power on off button is the red end key on the Razr
Posted on Jan 08, 2009
SOURCE:
I have a verizon razor but the ear speker went out
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone uses different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
1. Remove the 4 plugs over the screws on the flip top and the screws themselves. 2. pop the top apart and up at the top you sill see where the speaker just sits in there. 3. Replace it the way you saw it in there 4.put it back together Now you can hear your friends without speaker phone!!!
Good Luck!!!! ANd pls rate this post
Oct 13, 2009 | AT&T LG CU720 Cell Phone - Silver
Is there a mute button I can use while on the phone
yes when you make a call hit the menu button and select mute and visa versa and when the call is taking place you can hit the left soft key button to mute hope this was helpful:)
Sep 15, 2009 | Samsung BlackJack II Smartphone
Samsung BlackJack II - how to replace center button (stuck)?
in order to do that you will have to take the whole face plate the front and back off of the phone then you will be able the replace it just pop the wheel off and then the center button and replace everything and there you go hope this was helpful:)
Aug 03, 2009 | Samsung BlackJack II Smartphone
My razor won't stay on!
try a new battery and also take the phone and have the firmware reflash on the phone to correct this problem
Sep 30, 2008 | Motorola Mobility RAZR V3
Has been working fine, now Razor phone cannot find it.
hoping this helps...
Explorer Series: 220,320, 330, 340, 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
The passkey is 0000
Sep 18, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Samsung Blackjack II people can't hear talking on the phone
Hi jobare,
If you haven't already tried it, you may want to try a hard reset. (Warning: the hard reset process will erase all content and settings that you've added to or created on the phone.)
Hard Reset for BlackJack II:
1) Power off the BlackJack II
2) Hold the UP button on the directional pad
3) While holding the UP button, press and hold the Power button
4) When prompted, press the 1 (or 'E') key to continue
5) When prompted, press the 'Y' key to confirm
If this doesn't resolve the audio issue it's probably microphone related and you'll probably want to research replacement options.
Hope this helps!
Thanks,
The MoDev Kid
Jul 29, 2008 | Samsung BlackJack II Smartphone
Problem link insten hs120s with my blackjack 2
Hold both the up and down volume buttons on the headset until both the blue and red LED's flash in alternation. That sets the headset into "pairing mode".
May 04, 2008 | HP Insten HS120S - Bluetooth Headset Ver...
Samsung black jack i617
LOL. After reading the manual, you will find that the process to unlock is:
Press the power button (or the "1" or "9 "key) then the left soft button, then the "S*" key.
Apr 23, 2008 | Samsung BlackJack Smartphone
Blackjack phone
it uses micro sd card. try putting it correctly following the instructions on the Blkjack manual
Dec 29, 2007 | Samsung BlackJack Smartphone
Motorola Mobility RAZR V3c Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
