Question about Biostar A780L Motherboard w/ AMD Athlon X2 7850 Black Edition Processor Bundle (A780LWX27850BE)
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
  • Biostar Master
  • 3,606 Answers
Hello here you can download a manual:
http://www.biostar-usa.com/app/en-us/support/download.php
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=sMc5ukMguEo
Good luck
Posted on Nov 04, 2012
  • 238 Answers
SOURCE: Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Posted on Dec 17, 2007
SOURCE: Biostar Motherboard p4m800-m7a
please send to me for drivers motherboard p4m80-m7 biostar i needed you help
Posted on Oct 25, 2008
  • 61 Answers
SOURCE: Biostar GF8100 M2+ TE with AM2 and cannot install
Bad stick of memory? If you have multiple sticks, try removing one, then the other, and see how far you get with installation.
Posted on Jun 29, 2009
  • 38 Answers
SOURCE: biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: Problem with Biostar P4M800-M7A Motherboard
I had exactly the same problem.... waste hours on it. I solved it by clearing the CMOS. Pins 1 and 2 on JCMOS1 are closed in normal operation mode. Move the jumper to pins 2 and 3. I then pressed the power button a few times (the motherboard will not respond to the power button at all when it is configured to reset the CMOS), but I don't think pressing the power button is neccessary. After about 30 seconds, put the jumper back on pins 1 and 2, and power up. When I did this the motherboard responded finally. Hope it helps! :D
Posted on Mar 02, 2010
A DISK READ ERROR OCCURRED
Try Windows7 instead of XP, since XP doesn't support SATA drivers to read your HDD
Jul 08, 2014 | Biostar GF7025-M2 GeForce 7025 Socket AM2...
I'm getting a message saying that my hard drive can't be found
this is an easy one, your hard drive has failed this is why it does not show up, I am suprised that you dont hear clicking noise when trying to access the drive. if you have another drive around try to connect that one just to see if you give different error message but I am %100 you have a failed drive, I used to work at gateway/Quanta and have serviced thousands of machines with the same problem, good luck
Feb 03, 2013 | Acer Aspire 5735 Notebook
I'm getting a POST error
Don't format the problem is in BIOS. Try setting defaults.
Nov 20, 2012 | Biostar A780L3G Motherboard
PC shut off during update install now I get bsod 0x000000ED
I think you may know the answer already. It's a matter of sacrificing one of drives, if you can't purchase another drive right now.
Live boot with Ubuntu and copy just the data needed onto the other drive. You now have all the data on one drive allowing to wipe and reinstall XP on the other.
You may still have unresolved hardware problems, if the newly wiped drive blue screens again.
Oct 15, 2012 | Computers & Internet
Biostar TA790GXE 125M keeps shuting down when I boot windows, on SATA and IDE hard drives
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 31, 2012 | Biostar TA790GXE 128M 5.x Motherboard
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
Mar 22, 2012 | Computers & Internet
Hello. Completely out of the blue, when I turned my laptop on it immediately went to a black screen that said "A disk read error occurred press Ctrl+Alt+Del to restart." But when I do it takes me...
When your system boots it looks for a startup file which is located on your hard drive to load your operating system. If your system doesn't find your hard drive it would post a disk read error message.
To be sure your HDD is detected by your system, you can go to your BIOS setting by pressing DEL or F1 or F2 or F12 it depends on your BIOS maker then try to see on your BIOS setting configuration if your HDD drive is detected or not.
Sometimes and always happens that we forget a media disc on our optical drive and since the default first boot device is the optical drive the system looks for a startup file on it and post a disk read error. So check if you leave any disc on your optical drive and remove it.
It is very safe to configure your BIOS setting to set the HDD as the first boot device in case we leave something on our optical drive most of the time.
Hope this helps.
May 27, 2011 | Computers & Internet
I have no sound I install the driver but there is no sound.
Try to install the driver in the case where the card effected gently.So keep it up on that case where it can continue to work.
Apr 04, 2010 | Biostar K8M800-M7A Motherboard
Biostar A780L Motherboard w/ AMD Athlon X2 7850 Black Edition Processor Bundle (A780LWX27850BE) Logo
716 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
