Question about Samsung DVD-V5500 DVD Player/VCR
Insert a VHS tape, hear sound, no picture? DVD working fine, both sound & picture. What am I doing wrong?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Likely a damaged video tape got in the unit and blocked the video heads--once blocked no picture but sound will be the case---the heads can be manually cleaned if you know how---The real issue will be to locate which tape was in the unit when this happened--clear the heads and put it back and right back to no image......
Cleaning tapes are only slightly effective--most shops (if you can find one who even works on this gear) will not charge much to clean the heads.
Posted on Nov 04, 2012
SOURCE: vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Posted on Jul 14, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
SOURCE: Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Posted on Feb 18, 2009
  • 380 Answers
SOURCE: the VHS tapes will not playback on the Samsung TV
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Posted on Dec 30, 2009
  • 226 Answers
SOURCE: VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Posted on Feb 14, 2010
VHS won't display any picture but audio works???
how do you have it hooked up? there are different connections for the dvd and vhs sides of the player
May 20, 2014 | Panasonic PVD4744 DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
Sound but only snow for picture
make a deep clean ur video head with a video head cleaner or with a soft cloth with some mild soap.
May 06, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
No picture on vhs tapes
Is the picturejust snow or no picture at all? Most cleaning tapes won't work if the heads have been clogged up because of a bad tape. A professional cleaning and alignment may be in order here. Can you clarify the lack of picture please?
Thanks,
Dan
Nov 14, 2008 | Daewoo DV6T844B DVD Player/VCR
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
This machine plays DVD discs fine but can only hear the sound with VCR tapes
Try first to clean the video heads then if that dosent work take in the machine to have the heads professionally cleaned. God Luck
Jul 27, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Samsung DVD-V5500 DVD Player/VCR Logo
159 people viewed this question
Henry  Thomas
Henry Thomas
