Question about Lexmark Prospect Pro205 All-in-one Inkjet Printer
The printouts from my printer look fuzzy, like they are out of focus or something. It looks like two pages on one with one page just slightly off center of the other one.
  • Official Brand Answer
  • 3,344 Answers
Make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Also, try to perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If the steps provided above doesn't help, download the updated driver for your printer online: http://bit.ly/iU5gjI. Just choose the operating system of your computer.
Posted on Nov 09, 2012
2 Suggested Answers
  • 51 Answers
SOURCE: Prints PDFs VERY, VERY Slowly...Something's Wrong...
See if print spooling is turned on. If using windows check the control panel or use task manager to see if spooling is active and running
Posted on Jul 11, 2012
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Slight fuzziness when taking pics of my artwork
What you need to do is take your photos of your artwork using your camera's macro mode. The macro mode button looks like a flower. Macro mode allows for precise focusing on close up subjects.
Check page 41 of the manual:
http://service.us.panasonic.com/OPERMANPDF/DMCFS15.PDF
Jul 07, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Hi when i print lines appear in my printout - i have ran the maintenance checks and nozzle check utility seems fine although the black looks a bit fuzzy - do you know how to resolve this problem please?...
If you haven't done so, run the alignment setup again. If that doesn't work, put in new cartridges and see if there are still lines in your printout. This will check if it's a printer issue or cartridge issue. Here's a PDF from epson on how to run the alignment setup. See page 11. http://files.support.epson.com/pdf/r300__/r300__pg.pdf
Mar 01, 2011 | Epson Stylus Photo R300 InkJet Printer
All my printouts on my Phaser 8400 is fuzzy and
What normally causes that is the Drum motor encoder picks up the lubrucant from the drum and makes the drum spin to fast and or just out of sync.
It is located on the right side of the machine. I reference that looking from the front. To remove the right cover you remove one torx screw from the top back and one inside the paper path door in front, near the top. Then when those 2 are removed you lift up and out on the cover.
The encoder is on the end of the drum shaft. You can remove it and clean it by pouring alcohol over it, wiping it gently then allow it time to dry.
That should take care of it. If not then the encoder will need replaced.
If you go to Xerox.com and click on support and drivers, enter 8400 in the search box, and it may be on the support page or the documentation page, but there is a parts list on the site that you can look at as a reference or also to get a part number to order a new one if needed. Using the parts list is the best way to be certain you are getting to the correct part and not guessing.
But I am about 90 percent certain that the encoder is the issue.
Feb 23, 2010 | Xerox Phaser 8400 Laser Printer
No hint of toner shortage but printouts lack color
Can be short of toner before the pagecount is at max for the capacity of cartridge.
If you look at the roller at the edge of the toner cartridge, it should have an even coating of fairly dense toner.
Remove each toner in turn, shake, and reinstall. This will often give you a few more pages.
Rated capacity is a guide based on a 5% page coverage.
Some remanufacturers are a little 'economical' with the toner they put in their catridges.
Jan 20, 2010 | Samsung CLP-510 Laser Printer
When i am giving a single page printout it will printout another copy of blankpage
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
Nov 03, 2009 | HP Inkjet 1200dn Printer
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
Printout quality
Check the Tech help line at Canon. If it still in the warranty period this is the route to go. Certainly looks like no user adjustment is possible
May 14, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark Prospect Pro205 All-in-one Inkjet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
