Question about Dell Inspiron 1545 Notebook
Battery wont charge dell inspiron 1545
The part that the battery plugs into in the laptop burned out, how do i get a new one and what is it called?
  • Tammy Wentworth Nov 05, 2012
    rge the battery
  • max carson
    max carson Nov 05, 2012
    I don't understand "rge the battery". Try again. The part I think you are talking about would be a AC jackhttp://www.google.com/webhp?source=searc...
  • Dell Master
  • 7,627 Answers
Buy a replacement cord\charger at a computer store or online, make sure the power specs match. If you are refering to the AC power plug JACK in your computer, similar to this:http://www.parts-people.com/index.php?action=item&id=9377&gclid=ciw47k7sulmcfqufnqodreeaew. I would take it to a Qualified Computer tech, or send it to the manufactor, Dell in you case. Unless you have the tools and expertise. It can be done but are you comfortable doing it?
Posted on Nov 05, 2012
ArnWuLF
  • 55 Answers
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Posted on Nov 25, 2008
Sameeraryan
  • 82 Answers
SOURCE: battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Posted on Jan 19, 2009
DosHog
  • 168 Answers
SOURCE: My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Posted on Aug 01, 2009
  • 151 Answers
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
Posted on Apr 28, 2010
  • 2567 Answers
SOURCE: My DELL inspiron 1545 laptop keeps restarting
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 23, 2010
Plugged in, not charging
First, try another charger. Perhaps your charger isn't providing enough volts to the laptop
Feb 27, 2014 | Dell Inspiron 1545 Notebook
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
New battery wont charge in my dell inspiron 1545 where it plugs into the laptop burned out
It's probably the connection that's the problem. If the wiring is damaged, it wont likely pass a current to the battery itself. I suggest getting your laptop serviced.
Nov 04, 2012 | Dell Inspiron 1545 Notebook
Inspiron 1545 how to reset power adapter
1 Possibly the generic power supply plug has the wrong polarity.
2 Possibly the plug is not quite the right size for your PC, hence not making good contact.
Nov 25, 2011 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 laptop has went through 5 chargers they work for 6 months and then say does not not charging does not recognize battery
This is similar problem I had on my laptop.
Its a problem with the battery not the Charger If computer is in Warranty you get it from Dell or buy a new battery
Jun 21, 2011 | Dell Inspiron 1545 Notebook
Dell 1545 battery plugged in not charging at 9%
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 30, 2010 | Computers & Internet
Back-up battery wont charge and LED at the front of Laptop flashing
Find a good repair engineer to repair it, if if can't be repair any more,just pay more attention to the Dell inspiron 1545 battery not charging question for answer,and learn more laptop battery maintenience tips from now on.
Aug 07, 2010 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 says plugged in but not charging
its the charger if the charger is longer before trie changing the battery or if that doesnt work u have to replace the motherboard (around 155.00 GBP)
Jul 26, 2010 | Dell Inspiron 1545 Notebook
Dell laptop wont turn on
first change the battery then check the charger if the problem still occurs then it will be hardware problem, it is better to check it on the dealer if ur laptop is under the warranty.
Oct 23, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
