Question about Kodak EasyShare Thermal Photo Printer
Printer dock won't print. Says ''no Paper,'' but is full
Full of paper, goes through the motions of trying to pick up the paper, but then signals ''empty'' I have the same problem. The printer is full of paper, goes through the motions, of printing, and then tells you out of paper or unplug for 5 seconds?
  • 3 more comments
  • Anonymous Jan 08, 2009
    I have the same problem as Vonda. I just reied to clean the rubber roller with 100% alcohol.
  • mikekington Jan 15, 2009
    Yes. The printer tries to feed the paper but the feed wheel just spins and the paper doesn't enter the printer.
  • Anonymous Mar 07, 2009
    Full of paper...says out of paper...add paper then press print.
  • Anonymous Apr 02, 2009
    It says to inser paper then press print. But it is full of paper.
  • lineandgrade Apr 04, 2009
    Would the clear plastic cover for the paper being missing keep it from printing? If so where can I get one?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Printer feeder is not picking up the paper to print. Goes thru the motion like it is going to print but does not oick up the paper in the paper tray????
Please reset your printer ... your printer ink absorber is almost full. Follow the instruction... 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal. thanks....
Aug 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Cant pick up paper
the dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
Jan 19, 2010 | Kodak EASYSHARE G610 Thermal Printer
The photo paper does not feed into printer. I
Get hold of the photocard and try, with your fingers, to curve the end that goes into the printer first so that it doesnt resist as the machine tries to pick it. Just curve/bend it little upwards, not downwards. Usually this kind of problem is temporal and happens especially when the card is a bit too hard for the machine.
Dec 09, 2009 | Office Equipment & Supplies
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Out of Paper
make sure that the paper is kodak xtralife with perforated tabs, otherwise the printer will really not pick it up and if it would - it's gonna be a really bad print
detach all the things that are attached to the printer.
grab a piece of lint-free cloth, wet the other end and leave the other end dry
clean the roller horizontally
use the dry end to dry up the roller and watch for water build ups
have at least 10 photo papers in the paper tray
slide the paper tray back into the printer
plug the printer onto the wall outlet, wait for the initializing sound
put cam to the printer dock
print a picture
Jan 20, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Paper Feed Problem
This is caused by the solenoid that is activated when picking up the paper. The solenoid is activated and the device goes through the motions of picking up the paper. It fails to pick up the paper or fully feed it past the leading edge sensor resulting in a jam error. You should replace the pick up solenoid assy and also the pick up roller and friction pads.
Jun 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Kodak EasyShare Thermal Photo Printer Logo
433 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
