Question about Dewalt Heavy - Duty 10" Wet Tile Saw - D24000
Crooked cuts I have a 10" wet saw that has cut lots of tile in the last year and is in mint condition. I went to cut a peice of 12" marble and the blade starts to wobble as soon as it comes in contact with tile. It free spins true and I even went and bought a new blade. Starts to wander and blade flex as soon as it comes in contact with tile still. Blade is tight on arbor and water is flowing well. Have cut this same tile about a week ago with no problem. Also blade seems to be square with table. Any advice?
  • Anonymous Mar 17, 2014
    we need to repair a target wet saw because the blade wobbles while cutting.
  • 10,865 Answers
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
12 x 12 marble tile I have put that up twice don't know why it is not appearing
60 if there are no cuts.
You usually add about 10% for waste. So 66 tiles should do it.
Jun 11, 2015 | Instant Mosaic Metal Tile: 12 in. x 12 in....
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
What is a wet saw? is it easier to use than a tile cutter?
Wet saws make cutting thick or strong tiles easier, they also make it easier to make multiple cuts on a tile. It takes longer to use the wet stone so if you don't really have to use it then cutting with a tile cutter will go much faster.
Nov 17, 2013 | Cutter Tools
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Dewalt Heavy - Duty 10" Wet Tile Saw - D24000 Logo
1,256 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
