Question about Thetford Porta Potti
Thetford fridge type C11[fitted to caravan]model N80 PL R
Trips on 240 volt mains
there has been a mild smell of ammonia in the van
Is the heat ex naff ????
Geoff Hounsome
  • 30 Answers
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Posted on Jan 07, 2009
Today i found my thetford fridge in c/van not working on 240 power so i turned it on to gas and it workes. Any idea what might be the problem?
the fridge works by heating crystals that creates a gas that is the refrigeration
if it works on gas then the system is good and indicates that the 240 volt heating element is not working
find a caravan repair center and have it checked out
Nov 25, 2016 | Thetford Refrigerators
Thetford N80 fridge will not work on mains
check fuse inside control box of fridge then check heater elements
Jan 19, 2015 | Thetford Refrigerators
I have error code 8 on thetford fridge how do I remove code to used on 240 v
If switching off and on again doesn't clear fault 8 (ac volts 20% lower than spec) you may need to replace the board for one with a resetting fuse.
May 19, 2012 | Thetford Refrigerators
Fridge emitting burning smell. Its a fridge in a new caravan
Had smell probs with ours sorta gassy and what seemed like overheating and lack of cooling Found " exhaust pipe " completely choked - cleaned it out and all fine.
Apr 23, 2012 | Thetford RV Refrigerator - N400 Model -...
Smelling burnt gasses
Make sure your roof vent is not clogged immediately. If you are in a full service park, you should be running on electricity not propane. You don't describe the gasses you are smelling, if it is ammonia, your frig is probably done for.
Ammonia is the primary ingredient in the cooling process. What happens is the ammonia is boiled and then sprayed throug an orfice. The spraying creates the cooling (heat removing) effect. If you are smelling ammonia, your boiler has developed a leak.
You can purchase replacement units to install in your present frig. Some people have success with this. My experience was not so good. I spent about $225.00 plus shipping for a rebuilt unit (with a 'core' charge). I did the work myself. I got about a year out of the rebuilt unit before I simply replaced the frig with a new replacement 3 way Norcold. My new Norcold was much improved over the earlier model and included a ice maker! It was expensive, however, at more than $1300.00. Find sources for replacement cooling units for your "Thetford" refrig at FixYa.com advertisers or through your RV dealer or in the back of travel trailer magazines.
I hope this is NOT your trouble and I hope you find resolution. Thank you for your interest in FixYa.com and please come again.
Jul 24, 2011 | Thetford RV Refrigerator - N300 Model -...
Fridge will not work on gas
If you're sure the gas is igniting and making heat, you may have lost your refrigerant. It probably is ammonia, which smells very strong. Check your dealer for someone who can check it out.
Apr 27, 2009 | Refrigerators
Thetford caravan fridge freezes all food in fridge does anyone else have this problem / what can be done? Not sure of actual model but on manual says N80 - N150
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Mar 29, 2009 | Refrigerators
Thetford Porta Potti  Logo
982 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
