Replace hard drive - Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
You need to find a guide for your specific laptop and open the shell. You'll need to look up guides for your specific laptop to know how to get to the hard drive itself. Yes it is possible, but you should only do it if you really want to upgrade or your hard drive is damaged.
Posted on Nov 04, 2012
HD REPLACEMENT
Check if you can use SATA else you'll have to look for IDE
Actually to insert a SATA drive is easier then replace a light-bulc.
Just remove cables, unscrew from "drawer" insrtn new drive, scress, replace cables.
If it's a system disk, the difficulty is resintall your system. After you've replaced Hard disk, formulate your question with more doubts
See some fine videos here
How to install SATA hard drive into computer
How To Install Internal Sata Hard Drive and Activate In Windows OS
How to install and remove SATA Hard Drive
How to Replace Desktop Hard Drive
How to Install Second SATA Hard Drive
Jun 27, 2015 | Computers & Internet
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
Hard Drive
You can replace it with a larger one, just make sure you buy the proper hard drive. If its and IDE hard drive, buy and IDE hard drive, if its an SATA Hard drive, buy an SATA Hard drive. also make sure after you install the new hard drive that you use the operating system cd to format the drive and to install the operating system.
May 04, 2009 | E-Machines T1840 CELERON 1.8 GHz 128 MB 40...
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
