Question about Maytag MAV7600 Top Load Washer
Drum spining out of balance
Drum spin out of control, shaking machine making it vibrate out of control.
  • Anonymous Mar 27, 2014
    clanking sound when machine is trned on and the drummis not spinning
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check inside to see if one of the drum springs has come off or broke.
Posted on Nov 04, 2012
Crustacio
  • 3 Answers
SOURCE: My Maytag washing Machine Shakes/Vibrates loudly
If you have a top-loader, there are two or three heavy-duty springs inside the cabinet that attach from the drum to the frame. If any of these has come loose, high rpms will cause the kind of shaking you describe.
Posted on Jul 30, 2009
sdmc73
  • 121 Answers
SOURCE: Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Posted on Dec 02, 2008
  • 20 Answers
SOURCE: Unending Heavy Vibration on Spin Cycle - Maytag Neptune
level the machine, if you are on a wood floor it could be the floors fault, you could try using aanti vibration pads.
Posted on Feb 13, 2009
BIKER T
  • 909 Answers
SOURCE: Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Posted on Sep 16, 2009
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Posted on Oct 09, 2009
My GE washer GTW460NMKwww, the drum will not balance itself when going into final spine cycle.
Are the clothes evenly distributed inside the drum and the washer not overloaded? The drum is not self balancing, you must take care when loading it to even the weight distribution
Mar 01, 2017 | GE Washing Machines
It shakes excessively on spin cycle, machine is level, it does it on every load, it is beginning to tear up door seal
It shakes when off balance. Your wash load may be balanced but the drum may not be. This could be down to the drum bearing or the "spider" that holds the drum in place. If one of the arms is broken it will spin off balance.
Oct 26, 2015 | Washing Machines
Why washer moves and vibrates all over when spinning
There must be the correct weight in a washing machine. If it is under loaded then the drum will spin out of balance because the weight is trapped to one side. regualar use like this will break the drum bearings.
Weighty things like towles & sheets have to be balanced around the drum prior to spining, that's why the drum does slow and quick spins to even the load out. apart from that one of the drum supports need attention.
Oct 03, 2014 | Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
May 26, 2011 | LG WM-2277HW Front Load Washer
Washer shakes when spining. More on heavier loads.
shaking is generally due to inadequate floor structure under machine; i.e. plywood floor. in addition, if the washer is on a "pedistal" it will make matters worse; as the center of gravity is away from the floor. in rare cases, one of the drum "struts" can fall apart; and, cause excessive shaking. if you broke the locknut on one of the legs, unscrew the leg, and bring it to the hardware store for a replacement nut.
Feb 15, 2010 | LG WM2487H Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Vibrating Front Loader
An experienced appliance technician can quickly check the balance of the machine. If the tub is off-balance or one of the balancing springs has been damaged then the technician should be able to resolve the problem without too much trouble.
Installing anti-vibration pads is also a good solution. Some pads are much better than others. Pads made of hard neoprene rubber are okay but try to find something made with a urethane rubber or multi-compound material. My appliance repair tech swears by Silent Feet pads from The Vibration Solution.
Jun 27, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Maytag MAV7600 Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
