Question about Kenmore Elite 45986 Front Load Washer
My kenmore He is not draining the clothes are ver wet. timing is wrong I cleaned out the pump it still isnt draining not draining
The washer was down for 5 days we had no power i did 1 load and it worked fine the second load beeped a lot I check ed the pump took out a pencil thinking that was the problem but it is not draining at all it spun and said SUD even though i use minimal detergent and the timing is messed up I have unplugged it and restarted too
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
If you have a wet-dry vac, put it on the end of the drain hose and **** it out. There may be something blocking the line that you can't see.
Posted on Nov 04, 2012
SOURCE: Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Had same problem. Followed advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
Posted on Dec 13, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE4t Washer
I believe the SUDS error is in direct relationship to the clogged drain problem. Yes...the error can be generated by the use of too much soap. But, it is also caused by too much air in the drain pump. This is caused by a clog somewhere. A clog in the drain area of the gasket is not going to cause this. The problem is your drain line and/or drain pump. If you click on the link below, I have step-by-step instructions on how to access the drain pump and clean it out.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
I have experienced on one occasion where the drain hose coming from the bottom of the wash tub was clogged. This, ironically, was from someone washing a rug that had a ton of sand and dirt in it. I had to remove this hose from the bottom of the wash tub and clean it out. I mention this just in case cleaning the drain pump is not enough.
I hope you find this information helpful. Reply back if you need further assistance.
Posted on May 15, 2008
  • 33 Answers
SOURCE: HELP!
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Posted on Jul 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: hi, i have a kenmore
Drop front panel
open pump sump
clear objects.
Retry
Posted on Jan 08, 2009
  • 44 Answers
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Posted on Jun 10, 2009
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
Aug 15, 2014 | Kenmore Elite HE5t Washer
Kenmore washer model 15862400 leaves clothes really wet, why
Possibly a blockage in 1 of the outlet pipes or pump causing water not to drain out properly.
Dec 22, 2012 | Kenmore 24032\24036 Top Load Washer
How to clean drain pump on kenmore connect washer
Good morning I ampretty sure that I have answered this more that once.
Kolbrun
Nov 28, 2011 | Kenmore HE2 Plus Front Load Washer
Clothes are sopping wet even after doing the spin cycle 3 and 4 times, water is going through hose fine it seems, it a front loader
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Kenmore Energy Star 44092 Front Load...
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE washer -clothes still wet sometimes
checked the drain? didi you physically open the drain pump asssy, and clean the filtero out???
Feb 09, 2010 | Washing Machines
I have a Kenmore 3.5 washer model # 44152. The washer is going through all the cycles but for the final spin it does not spin. Thus leaving the clothes sopping wet. What is wrong?
Is your pump clear? Nothing is in the pump blocking it? Does it drain ok? Check out your pump buy removing the bottom panel..Then check you drain hose where ever it is draining into, make sure drain isnt tp far into drain, or sink becausewater will syphen back into washer...try checking these simple checks first. i think your pump has a screw in type plastic cap. unscrew and check if you have anything in it and nothing is restricting the inpeller. spin the impeller with you finger make sure it spins around freely. you will feel some tension from the magnitation it is getting. but yeah, try these simple checks first and see what happens....
Jul 31, 2009 | Washing Machines
Oasis washer displays code Ld and wont fully drain
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
22 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
