How to fix Sony DAV-DZ640 no sound and video ?
Please help me!
4 Suggested Answers
SOURCE: Sony DAV-BC150
Sounds like your TV's sound output isn't working. Check all the connections and if that doesn't do it, try hooking up some other sound system to the TV to check that it is working properly.
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Can i play vidio player via my sony dav-dz330
Your Sony DAV-DZ330 will play DVD video to your TV via HDMI (preferred method) or via SCART (analog video and sound) but you will not be able to connect another video player into your Sony since it does not have any video inputs.
Feb 28, 2011 | Sony DAV-DZ100 System
I can't go to the ''DEC.MODE'', following the instruction manual of my Sony DAV-DZ777 so I could not enjoy the surround sound, it worked normally then just suddenly this problem occured. Help me please!
Help me please!
Feb 22, 2010 | Sony Audio Players & Recorders
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
I want to connect an external DVD player (Samsung DVD-1080P9) to my Sony DAV-S500 system
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
ANY QUIERIES MAIL TO ME
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jul 11, 2009 | Sony DAV-S500 System
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Home Theater Systems Sony DAV-HDX465
you will probably have to select you wii int an input on the reciver.sometime the reciver will use an aux secection
Mar 18, 2008 | Televison & Video
Sony DAV-BC150
Feb 22, 2008 | Sony DAV-BC150 System
43 people viewed this question
 Grubhead
Grubhead
