Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water Dispensor leak on Whirlpool Refridgerator
Whirlpool Gold Refrigerator Model GS6SHAXML00, how do you fix a water dispensor that is leaking. A technician replaced it 8 months ago but it is leaking again. It just constantly drips.
  • 1 more comment
  • udbill Jan 10, 2009
    Thanks for answering. Where on the back of the fridge is this? Is this something a novice do it yourself guy could fix? Any pictures or videos that would show this.?
    Thank you
  • Owen Shaw Feb 06, 2009
    Whirlpool model ED22WDXTNO2 mfg 1989 just started drip from door water dispenser. Not much so I place a glass under the dispenser and catch never more than enough to cover the bottom of the glass.I woul like to fix the leak.
  • Anonymous Mar 31, 2014
    when using water dispensor, water leaks from rear wall mounted plastic manifold
    inside
  • 198 Answers
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
  • tom weber Jan 10, 2009
    Take the back off the ref. and you will see where the water line is connected. If you also have a water disp. you will need to replace the whole valve which is a duel valve.
  • Official Brand Answer
  • 3,100 Answers
I had a similar issue. with my Kenmore Coldspot refrigerator. The Sears store locally helped me locate the part. Ended up getting it off of Amazon though because it was quicker than getting it direct from Sears. Here was the part I got. http://www.amazon.com/gp/product/B001DPOZWU/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Posted on Jan 03, 2014
Why is the water coming out of the dispensor not cold
Is your fridge compartment temperature in the region of 2 ~ 6 C range. Is your fridge food not going bad. Then dispensor water should be cool. Cool water tank is normally hidden inside fridge compartment. Lowest temp is around 2 ~ 6 C range.
If you keep on taking water rapidly then there is no time for the cooling tank to cool. You are just pushing house water through the water dispensor.
Oct 03, 2014 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I own a whirlpool gs5shaxnl refrigerator that has
Hi Slick;
You have to take off the front dispensor mechanism and clean.. Be Very Very carefull as these are common for breaking.. It is hard to explain how to repair without having it in front of me.. hope you understand..Cheers
Mar 23, 2010 | Whirlpool GS5SHAXN Side by Side...
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Water Dispensor leaking - HELP
shut off for the water supply igenrelly under the kitchen sink or in the basemant. no need to shut off main water supply to home. only to the unit itself
Oct 27, 2008 | KitchenAid KSCS25FKSS Side by Side...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
660 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
