Question about Whirlpool Washing Machines
Manual for lha7680w1
Dum turn all the time timer not working
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Are you looking for the user manual or the service manual?
Posted on Nov 04, 2012
How can I manual turnon my nelson timer
Open following link to help identify Nelson timer, then re-post question with model number so expert can access the manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
May 30, 2012 | Nelson Hardware & Accessories
Otsky.com It says to push segment PINS for On, but I have no pins???
You posted under Woods 59382 timers.
Open following link to identify timer for sure.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59382
This timer has segments around edge of dial.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Open following link to see sample pins, tabs, segments:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Turn lamp ON, plug lamp into timer. plug timer into working outlet.
Manually rotate timer dial and watch when lights turn on-off to verify how to set segments and switch.
After correctly setting segments and switch, manually rotate timer dial until current time lines up with arrowhead or mark on timer dial.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
How do I work this timer? Model 59200. Does it work on any kind of lamp? Do I turn the lamp on? Tried it and didn't work, never turned the lamp off. Manual sheet not much help. Thanks for more info. Rita
Open following link to identify timer and see manual plus written programming steps:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Lamp must be turned ON, and Bulb is good.
Raise and lower a few segments on the timer.
Plug timer into wall, and plug lamp into timer.
Manually rotate timer dial clockwise to watch lamp turn on-off.
Notice also that timer has switch located on top.
Move switch into one position and manually rotate dial again.
Move switch to other position and manually rotate dial again.
This will tell you how to set timer switch and segments.
To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and segments click a switch back and forth that turns circuit on-off.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 07, 2011 | Woods 59200 Lamp and Appliance Timer with...
Hpm 24 hr manual timer , i dont know how to get it working
HPM 24 hour timer has segments located around dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM-dial
http://waterheatertimer.org/images/hpm-24hr-timer-500.jpg
Segments appear to move up or down.
Other similar timers: Segments down = Load ON; Segments up = Load OFF
Press several segments down.
Plug timer into wall.
Plug 240Volt load into timer.
Manually rotate timer dial clockwise to see if segments down turn load on or off.
There is also a 2-position slide-switch located on top of timer.
Move slide switch to each position to see which is need for timer to turn load on-off.
After positions are defined, push segments down or leave segments up for times you want load to turn on.
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Timer dial rotates as time passes, and segments move a plastic lever that turns load on and off
Jan 20, 2011 | Hardware & Accessories
I have an intermatic indoor outdoor timer the mototor is working (visual check) but it stays stuck at set time will not keep time any suggestions Hi, my outdoor timer stopped working last night . reset the...
On the model that I have you set the time by pulling the dial out and turning it to the current time.  If it does not "seat" fully when you release the dial it will not engage teh timer gear.  Make sure it is seated by trying to move it slightly in both directions.  If it turns frely it is not seated.  If there is some resistance (don't force it) then it is seated and should keep correct time.  If you have moved the manual lever to the ON position and the lights still do not work you need to make sure the power to the time clock is live.  The timer motor (and the lights) will not work if the power supply is off.  If the power is on and the lights still aren't working on Manual then there is a problem beyond the time clock (broken wire, burned out bulbs, etc.).
May 28, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Front speakers
dum...dum..dum..
do u people know
how to live or READ?!
OMQ GET A CLuE
Feb 02, 2009 | 2002 Chevrolet TrailBlazer
Kenwood KAC-8103D short?
sounds very similar to something that has happend to mine. if you check the fuses in the amp and they are fine, i recomend replacing the fuse in the power wire. if you are using the glass tube type fuses, sometimes the soldering at the endcaps melts, but the filament doesnt pop. the fuse appears to be fine, but isnt. that happend to me a few times. i had to upgrade to ANL type fuses
Jan 11, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Sidekick 3
dum *** you connect it with another baddery dum ***
May 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Washing Machines Logo
279 people viewed this question
Dan Webster
Dan Webster
Sal De
