Gateway laptop 450 rog
After booting I get to windows XP screen and then scrren goes black...never get to my desktop.
I have tried f2 in bootup and have gotten to my Setup Utility screen...now what?
  • scfsportsmom Jan 06, 2009
    We have the disk and would like instructions from you to solve this. After the XP screen, it makes the windows sound like it is loading, but you cannot see anything on the screen, so no desk top.
  • Chase May 11, 2010
    When you say setup Utility screen do you mean the machines setup options or do you see a windows setup screen? If the screen is going black it sounds like you have a corrupted or missing file. If you have the Windows XP installation disk I can provide you with step by step instructions on repairing your installation so you don't lose any files or programs.
    Thanks,
    Chase
    Sergeant:
  • 366 Answers
Be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Posted on Jan 06, 2009
From black screen can't go to F2, blue scrren comes
Give this a try you probably have a mbr virus.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Sep 02, 2012 | Dell Vostro 220 Desktop Computer
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
I have a gateway gx7022e windows xp computer. When i try to boot it up the white letters pop up then the screen goes to the gateway screen and freezes. Then my num lock comes on but my keyboard wont work....
At power on / power up, look for the key during the bootup (black screen with white text), that allows you to enter SETUP. If none designated such as F1, F2 F10 etc, then quickly click the delete button a few times and that may get you into setup. You may have to turn off the computer if you miss that window of time if it rfequires pressing the delete button a few times. Keep an eye out for the Enter Setup key though. To turn off the computer press and hold the power button 'till is shuts down and resart the process until you get to the setup screen in bios. In setup bios environment, look for set factory defaults and then save and restart. That may solve the issue of the lockup.
Jan 10, 2011 | Gateway GX7022E (RBGX7022E) PC Desktop
I have dell 110L inspirion with XP professional.
I think your Windows installation is damaged. Boot from your operating system CD. (Go into setup mode F2 or delete during bootup. Go to the Boot select screen and set up to boot from CD. Place your OS CD in the drive and power on.) When it boots, it should give you the option of REPAIR. Select this and allow Windows to repair itself. I hope this helps you resolve your problem.
Nov 16, 2009 | Toshiba Portege M700-S7044X Notebook
After downloading windows xp service pack 3: screen turned black boot failure/won't bootup without CD old files missing screen flickers hardware missing
you will have to restor it to factory stetings there is nothing else i can think that you would be able to do
please rate my help to you
thank you.
Apr 22, 2009 | Computers & Internet
Gt 4016 will not bootup. Power is OK.
hit the key to go into setup usally f2 or del go to boot order screen and set cd rom as first boot device then try restore
Apr 07, 2009 | Gateway GT4016 Desktop PC
Scrren Goes Blank after the booting
Hello. Put your primary boot to hard disk.
Feb 22, 2009 | Toshiba Satellite M115-S1061 Notebook
450 ROG LCD Display
at the the top of webpage hit arrow on page in tool bar then you can change text sizes or zoom in and out.
let me know if that helps
also have you gone into device manager and update your display driver
if this does'nt help i can give another solution
Jan 23, 2009 | Gateway 450ROG Notebook
Dell Latitude D600 Bootup then screen goes black
bad display drivers, boot into safe mode (F8 on boot) it should let you use the computer, unistall the graphics drivers and reboot again in normal mode, when your in re-install the graphics again
regards
Nov 22, 2008 | Dell Latitude D600 Notebook
Gateway 450 ROG screen does not show or freezes
Hi, The only easy check I can suggest is on the memory. Flip your notebook so that the bottom is facing up. Locate a small panel (with 1 or 2 screws) roughly 3X3in. Inside would be 1 or 2 memory strips held in place by 2 retaining clips, one on each side. Moving the clips slightly away from the memory would free the memory strip and partially spring up. It can now be easily removed. With a pencil eraser, clean/rub on the little gold contacts at the bottom. The slot where they mate with their holder could also be cleaned with an old toothbrush. If the above does not correct the errors, then perhaps you are better off seeking the services of a qualified professional since the unit may have to be opened up and diagnosis performed on its various components. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | Gateway 450ROG Notebook
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
