Question about Moen Home
Can not get the shower vaule to shut off? moen adler l82691
jyackle5
  • 8197 Answers
SOURCE: how do I set
On the link below is the manual. On page 4 step 13 will tell you how to adjust the temp. Please allow time for the manual to load.
http://www.moen.com/shared/pdf/instruction_sheets/ins898d.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 05, 2010
  • 7 Answers
SOURCE: how to instructions for
Hi kcornman,
Here is the link for the instruction sheet for installation http://www.moen.com/shared/pdf/l82691pt.pdf
Hope this helps!
-Olivia from Moen
Posted on Dec 21, 2010
SOURCE: I have a Moen L82691
You could try, but most likely its the hoses that are reversed. try that first i'll bet you it'll solve the problem.
Posted on Feb 07, 2011
  • 9 Answers
SOURCE: how to install shower faucet
Do you want instructions from start to finish on top of the instructions that came with the faucet? Or are you looking for help with a certain step? Need help soldering? What is your question?
Posted on May 05, 2011
  • 961 Answers
SOURCE: Had the Moen L82691 installed
I think Moen is one of the easiest to work on and most trouble free there is. The only problems I have ever encouneterd with them is the mixing valve.This is the parts breakdown:
http://www.moen.com/shared/docs/exploded-parts-views/l82691pt.pdf
and a video
http://www.youtube.com/watch?v=J-SNBNijfQc
Of course you handle would have the set screw that holds it on. I would go to who ever you got the valve from and see if they will give you a new valve or, the video states Moen may provide a new one free. It's also possible, being a new install, that you may have had junk in your water lines that have now plugged the cold side of the valve. If you have some help, you may want to have someone taht can turn water off and on(slowly), cold first, and see waht kind of flow you have with valve out. Check for trash in the line and the valve first.
Posted on May 29, 2011
Shower won't work
Sounds like calcium build up. remove the shower head and clean calcium or replace the shower head. Let me know if this helped.
May 12, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
Moen l82691
Very common to get debris like rust stuck behind your valve or in the aerator in the shower head. Try taking off the shower head and cleaning the screen and discs. If the junk is behind the valve you'll have to shut the water off and remove the valve. Careful, there's a retaining clip that has to be taken out. There's a specialty tool for Moen valves (costs about $30. to help pull the valve assembly). Good luck
May 12, 2013 | Home
Dripping
you need to get a replacement cartridge moen Faucets have a tendancy to go bad you can lok up the part number at moen .com most faucets have a warranty if not the will ship a new one in about 3-5 days
Apr 11, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
How to install moen adler shower faucet
Doug-
Moen makes six models of the Adler shower faucet. You can find the specific installation manual for the faucet you have on their website, at LINK. Select the unit you have and open the PDF of the manual on the following page.
Regards,
DIYpro
Jun 05, 2011 | Moen Home
Installed a new moen adler tub faucet with shower diverter. When you turn on the shower water continues to come out of the tub faucet. Is there an adjustment or is it just the way it is??
Our Moen always dribbled a little since the diverter is metal-to-metal and doesn't really have any seal. The loss shouldn't be a stream though.
Nov 11, 2010 | Moen & One Handle Tub & Shower Faucet
I installed a Moen Adler faucet. It will not shut
You may just have a piece of sediment lodged in the cartridge from when the water was shut off during installation. Carefully remove the cartridge and turn the water on to flush out any obstructions. re install the cartridge and test.
Feb 18, 2010 | Moen & One Handle Tub & Shower Faucet
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Home Logo
44 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
