Question about Kitchen Ranges
I have a GE profile electric oven. My wife is cooking a 15 hr low temp recipe. I just noticed oven off after 12 hours. does it have a safety built in?
  • 1,543 Answers
Yes. Just think if you rushed to catch your flight for a three week vacation and forgot to turn your oven off before you left? If you check your use and care book, I believe it will tell you how to defeat the 12 hour shut off feature. (also tells how to set or disable the "Sabath" mode, among other settings)
Posted on Jan 04, 2009
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
Where can i find instructions for cooking a turkey in a bella cucina oven roaster?
Here are the settings
Turkey, fresh, 10 - 14 lb, 350° F, 15 to 17 minutes / pound
A roster is a roster... when it comes to cooking they all cook by time and temp.
Time and temps can be found in this rival manual:
http://www.rivalproducts.com/manuals/MANUALS/RO180_43_56431310.PDF
Here are 2 recipie sources:
http://allrecipes.com//HowTo/how-to-cook-a-turkey/Detail.aspx
http://www.food.com/recipe/perfect-whole-turkey-in-an-electric-roaster-oven-339453
With any search engine (google, yahoo et al) use this search phrase for more recipies:
Roaster oven baked Turkey
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Crock Pots & Slow Cookers
Temperature Contol
Replace the temperature sensor in the oven.
Jul 21, 2009 | GE Profile JB968 Electric Kitchen Range
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Oven temp
after youve cooked at desired temp(400) for allotted time. turn off oven, and restart at 350. it wont start up right away( its already at 400, but it wool drop in temp and cook at 350. good cookin to ya!!!
Mar 23, 2008 | Amana ARGS7650SS Gas Kitchen Range
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
98 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
