Question about Dryers
Hi - i have a creda TVR2 Dryer - the pipe although placed through a window was full of water and now the dryer will not heat
  • 3,463 Answers
The hose may be partially blocked, stopping the air from blowing through properly,check that there is no bend and that the hose is not sagging down as this causes the moisture laden air to condense inside the hose and create water build up.
The water has probably caused the thermostat or heater to fail.
To check the element and stat(s) you need to remove the rear panel of the dryer, and tyest with a meter.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
Hi I have a Creda Simplicity TVR2 tumble dryer, the drum is rotating ok but it doesnt get warm air going through it. the drying process takes a lot longer than usual. Is this something we can repair...
hellojean, the problem may be down to the heat sensors these's usually 2 of them and they are located at the back of the dryer with wires attach to them.you need some 1 with a multimeter to test them if 1 is faulty change both of them.if theses are ok the the element is the next thing to test hope it helps
regards
shaun
Sep 20, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
My creda reversair dryer no.37642 doesn't rotate, although there is heat in the drum. What could be wrong with it?
Most likely the drum belt is broken or the tensioner is broken this is not to expensive to fix and the belt can be bought at any applince store.
Mar 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Snapped belt
Watch the video and it will give you the idea, it may be a different model but it's all about the same to replace.
Nov 06, 2009 | Dryers
Kenmore 88752 - Dryer won't heat
We had the same problem and I pulled the unit out and discovered the dryer lint vent pipe was kinked inside the wall and full of water. It took be a full day of work but I ran a new vent pipe up into the attic and up to a static vent and now the dryer works great.
We had a service guy from Sears come out and he tested the heater strips and said they were fine and suggested I work on clearning the lint vent pipe
It worked great.
M
Mar 18, 2009 | Kenmore 88752 Top Load Stacked Washer /...
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
