Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer fills with water over several hours
The drum is drained and dry when I take out the clothes, but after several hours (overnight) there is water in the washer.   No blockage in the drain sump and I can hear water draining during the cycle. Water appears to be clean and fresh, not drain water
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance. There is either sediment in the valve preventing it from closing all the way - or the poppet is damaged.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
My expensive lg washer makes my cloths smell
Water is staying in the drum because it does not have the ability to pump put all the water. The only fix to this is after every cycle, take the little drain hose located near the bottom of the unit where you have to remove the cover, and take out the plug and drain into a small trash can. You will get about 4 cups water out of the machine. If this water is left overnight, it starts to mildew and will be washed over your next load. It's a design flaw, but this is the only solution. And one other suggestion, after you are finished washing clothes for the day and after you've drained out the remaining water, leave the door open overnight for the moisture in the unit to dry out.
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
29 people viewed this question
Sal De
 Brian Main
Brian Main
