Question about Honeywell Programmable Thermostat Heater
Heating and hot worker work separately but not together
When hot water comes on first and heating second there is no power on the CH connection. When CH is on first and Hot water second there is power on HW Off, HW On and CH. This stops the Y plan 3 way valve from going to position AB
  • Honeywell Master
  • 3,238 Answers
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Posted on Nov 04, 2012
  • 16 Answers
SOURCE: cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Posted on Aug 17, 2009
  • 16 Answers
SOURCE: my daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
  • 33 Answers
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Posted on Jan 17, 2010
  • 3238 Answers
SOURCE: My Honeywell 3 port valve in my CH/hot water systemis not working
Hi two things that go wrong inside the valve gets clogged up and blocks up in side, the valve in side and get worn sorry 3 things the motor on the top burns out , if you remove the top cover you will see a small motor with 2 orange wires on it you can remove the motor with 1 screw and see if its turning
Posted on Feb 08, 2010
  • 3238 Answers
SOURCE: Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
Posted on Feb 18, 2010
Need to separate heating and hot water - just have hot water on
You need a heating engineer to come in and do this.
Sep 09, 2017 | Water Water Heaters
Tip
Service menu codes vizio
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
L32
With power off, hold Ch UP and Ch Down together for 10 seconds.
While still holding Ch up and down together, push power, then let go.
Select OSD button, there should be a letter "F" in the lower right hand corner of the menu.
Then hold OSD and Mute/Exit buttons together until factory menu comes up. Make adjustments with remote, select exit, then turn off power to save the adjustments.
on Apr 29, 2015 | Vizio Televison & Video
Hi I hope you can help I had a plumber come around and move my hot water cylinder in to my loft and now I can only get hw if I have ch & hw on together if I put hw on by itself my boiler over he
There should be a gate valve on the pipe from the central heating to the cylinder, it looks like a tap and is normally beside the cylinder. This is used to regulate the flow of hot water in the heating system through the pipe coil in the cylinder. If this is open too much it will let the central heating pump most of the water through cylinder and won\'t heat the rads properly, if its closed too much it will do the opposite. Ss I said it looks like a tap, so turn it fully clockwise, and then turn it anti clockwise about half a turn. See how this works and adjust it further to compensate. Hope this helps. Some plumbers forget to fit these but its easy to fit one, just cut the pipe carrying the heating through the cylinder and fit a stop cock (TAP)
Jan 04, 2015 | Dryers
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
Siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Nov 05, 2012 | Siemens RWB29
Feb 08, 2010 | Honeywell Electronic Programmable...
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Cannot get central heating working,for honeywell ST6400 programme
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
