Question about Kenmore Elite 45986 Front Load Washer
Why my kenmore washer HE3 front load stay on wash cycle?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE3 washer errors f06 towards the end of the wash cycle, last 25-15minutes. Not every load.
F06 indicates a drive tach error. Remove all connectors, one at a time, from all control boards and replace back in position, being sure they are tight. Most of these faults are caused by poor connections, especially when they are intermittent.
Jan 12, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
