Question about Kenwood DDX7019 6.95 in. Car Monitor
Not powering up
My radio is not coming on at all
M&r electronics
there should be 2 power inputs in radio connector,1 for radio power other for memory. If you have both then radio would have to be sent out for repair.
Jun 26, 2014 | 1993 Cadillac DeVille
Where is the radio fuse located in a 2002 toyota echo? because my radio will power on, but no sound comes out.
If the radio powers on, the fuse is OK. You probably have a bad output section in the radio.
Jul 25, 2011 | 2002 Toyota ECHO
Power to radio but can not turn on radio
plzzz remove the resistence 10 k and put the hardware on roof and hit it and go
May 27, 2009 | Harley Davidson 426290 AM/FM Radio
radio microprocessor may have "locked up" after installing power back to radio. Unit will need to be cleared. Contact Iron Cross Audio (www.ironcrossaudio.com) for advice on how to proceed
May 02, 2009 | Harley Davidson 426290 AM/FM Radio
Radio Not Working
There are 3 fuses in the interior fuse panel that feeds radio.
no. 11(10amp) is ignition switch power to the radio it comes into radio on the TN/LB wire.
no. 27 (10amp) is hot at all times and comes in on OG/LG wire.
no. 12 (5amp) is hot in run or accessory and comes in on YE/BK wire.
Check these with 12V test light at fuse and at radio connector.
Mar 11, 2009 | 2001 Ford Escape
Wont come on
What won't come on? Is this a radio that won't come on or an amplifier? If it is a radio not turning on, check all radio fuses (both at fuse panel and under hood). If these are all good and the radio still doesn't turn on, then you'll need to remove the radio and check power behind it.
If you have an amplifier that isn't turning on, you need to first check power on the fused power wire coming from the battery. You can use a 12 volt test light (available from an auto parts store) to check for power at the amplifier power connections. Test the 12v constant power and then the 12v remote turn-on power. If either of these are out, check fuses on the main and make sure the radio is delivering 12 remote turn-on power. If you are still having difficulty, please see a professional car stereo shop. They will be able to diagnose the problem usually in less than 1 hour for a small troubleshooting fee. Hope this was helpful.
Sep 28, 2008 | Pioneer Car Audio & Video
Kenwood DDX7019 6.95 in. Car Monitor Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
