Question about GE Washing Machines
Where is the lint trap ge gtwn/gtan2800 washer?
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
mark_37388
  • 100 Answers
SOURCE: just looking for the lint trap on my washer
It does not have one
Posted on Mar 30, 2009
jsrock516
  • 5911 Answers
SOURCE: need to know how to clean lint trap and where is
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
Posted on Jun 23, 2009
  • 5 Answers
SOURCE: lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Posted on Oct 10, 2009
  • 14 Answers
SOURCE: hnwl 3136 lint in wash, how to clean
For general advice on cleaning a washer lint filter, try eHow: cleaning a washer lint filter.
Posted on Aug 09, 2010
Lint trap doesn't sit right in dryer. It sticks up and clothes ge caught on edges., ripping clothes
Take the lint trap out, and look inside the slot where it goes. You will see a lot of built up lint which will have to be removed so you can slide the trap back down to the bottom.
May 05, 2017 | GE Dryers
Where is the lint trap for a top load ge wash machine location
Their is no lint trap on that washer, GE washers are built to be sold at the lower end of the price scale and dont include features found on upper end appliances
Jul 23, 2011 | GE WBSR3140DW Top Load Washer
Cannot locate lint trap to fit my wsm2420 sazww washer dryer combo ge parts no will not fit
In the Kenmore equivalent, the lint trap is on the back wall of the interior of the dryer. If GE is the same then you'll see two vents at the back inside, one is the intake (where hot air enters), the other is the outtake, which contains a lint trap. You might have mistaken both for nonremovable vents. But one of them is removable. It should have finger holes or something to grab. Just pull it and it will pop out without difficulty. It's probably a two-piece unit (a grate on the dryer side and a screen on the exhaust side, with a space in between for collecting lint), which snaps or slips apart easily, then you can clear the lint, and then snap or slip it back together and just push it back in place in the dryer.
Jul 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Lint filter on GE wbsr3140dw
Open the door and lint trap is right in front, just pull up and it comes out. Clean and replace.
Sep 20, 2009 | GE WBSR3140DW Top Load Washer
Machine will not pump out the wash water
GE Model WSSH300G does not appear to have a lint trap.  Manual is available for free at: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90312-1.PDF
It talks about controlling lint by sorting clothes into separate batches.
May 30, 2009 | General Electric WSSH300G Front Load...
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Ge front load washer does not spin or drain
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Nov 16, 2008 | GE WSXH208A Front Load Washer
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
Will not drain or spin
There is another posted problem similar to this one if you look at GE front-loading washers.  I can tell you right now, though, that we just cleaned the filter (had the same problem as you) and everything is working perfectly now.  The bottom panel (on the front) of your washer comes off by removing 3 screws.  Our filter was full of lint, change, barrettes, etc.  I would highly recommend looking for that other post (has more information) or trying to clean the filter.  Hope this helps!
Oct 11, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
