Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
No picture So everything was working great. I've had the TV almost 2 years and today I turned her on and no picture. I could see the bulb was working from the light out the back. Audio worked just fine. I tried all the inputs and menu screens and nothing would show. No abnormal lights on the front. Any ideas before I spend a fortune getting it fixed? Any internal fuses or connections I could check?
  • 1 more comment
  • Carl Peterson
    Carl Peterson May 20, 2007
    I fixed it somehow!?!? So I started taking panels off, checked a fuse I could see and saw nothing wrong. As I was putting everything back, I noticed a switch that is pushed in when the lamp access door on. I reset it by hand a few time plug her in, and presto! it worked. I don't know if it may have been it was unpluged for an hour or the switch, but I thought i'd let everyone know who may have this problem.
  • Carl Peterson
    Solved!!! check comment above.
  • Carl Peterson
    Carl Peterson Jun 03, 2007
    Well maybe im not so lucky......As the guest said their's has been doing it for over a year, well looks like mine might be falling in the same category. Every Sat since this first happened the TV will have no picture. Im waiting for about 30 min right now and ill plug her back in. Kinda strange this happens once every 7 days! I guess we know why Zenith dosent make LCD projections anymore. Class action lawsuit anyone? ;)
I hope youre lucky enough for that to be the only time, but mine has been doing this for over a year, getting progressively worse. As of the last 2 days, it has to sit over night b4 it will show an image again. Good luck with this B.S. tv. (Just spent $250 on new bulb last month too, had set 2 yrs. )
Posted on May 23, 2007
Hdmi on insignia lcd 37 not working
just upgrade, really not worth fixing. sounds like board is bad
Aug 01, 2012 | Insignia NS-LCD37 37 in. LCD TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
No sound, and no picture today. Everything was fine yesterday. 3 years old
is the tv a rear projection if so it the bulb you will need to replace it
May 30, 2009 | Panasonic Televison & Video
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV has sound but no picture
Everything is worth fixing provided the price is right.  However, in this case it's probably not cost effective to repair the unit.  Start with the easier fixes, such as bulbs, etc.  Even then, some of the components can be quite expensive, or simply unavailable.  I would suggest getting a quote from a local repair shop in order to make an informed decision before you get to far into it.  You could end up spending just as much to repair it as you would on a new unit.
Oct 19, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
No picture
set is gone it shut down,call local service dept.
Apr 12, 2007 | LG 52SX4D 52" HDTV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
