Question about Refrigerators
I have a GE refrigerator (model GBS20HBSAWW) and the original fan for the compressor coil wasn't working. So I bought a new fan, put it in, and it still doesn't work. I have 12V coming out bet
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
White to red should read 12Vdc. Since you read the correct voltage and used white as the reference, you have your neutral. This can only mean that the manufacturer has shipped out a bad new part. Re-order and send the other back for exchange or or order it here.
Posted on Nov 04, 2012
  • 2 more comments
  • nick Nov 05, 2012
    Thanks for your reply. I'm going to re-order a new fan, but I think there may be something wrong with the signal before it goes to the fan. Do you know how these fans turn on and off? I know that there is always around 12V being supplied to the fan, but what actually turns it on, and can I monitor this some how? Thanks.
  • Richard Roth
    Richard Roth Nov 05, 2012
    The fan should kick on when the compressor kicks on.
  • nick Nov 05, 2012
    Alright. Is there anything else I can check besides the voltage. What about the blue wire?
  • Richard Roth
    I would just get a replacement fan.
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
SOURCE: GE Refrigerator Eva. Fan Motor
which is the part number of the evaporator fan motor for refrigerator model GTS22KBP?
Posted on Nov 21, 2008
Sea Breeze
  • 4654 Answers
SOURCE: freezer and refrigerator not cold fan working but
I'm ready to help you when you are. Zero may just be off on that model but if fans run then the compressor is also getting power and overheating. The start relay and components that keep the compressor going are what important now. Don't leave plugged in or the internal overload may damage. I will wait for a reply, Sea Breeze
Posted on Dec 18, 2009
  • 4 Answers
SOURCE: refrigerator does seem like its working right
Your refrigerator compressor is either pumping or it is not. Set the refrigerator to low temperature, pull it out and listen for a while to see it the compressor is coming on. If it is coming on then there may be a freon leak or the internal coils may be iced up. If it is not coming on, then either there is no power to the coompressor, or the compressor itself is defective. Use a voltmeter at the compressor to check for voltage. There is also an add on device to start stuck compressors from your local HIVAC jobber store.
Posted on Jun 07, 2010
  • 351 Answers
SOURCE: Ge monogram zisw42emd, evap fan not coming
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Posted on Oct 08, 2010
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
Fans going-but compressor kicks in for about 8-10 seconds and cuts out-will not get cold or freeze-coils at bottom were very clogged with dust--they were vacuumed and blown out--made no...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Kenmore Side by Side Refrigerator
Ge model #gss25tgmf ccaf 419054 freezer doesn't stay at freezing temp.. sounds like motor and fan kick in but i was wondering if it might need free on it
heatman101
Aug 27, 2011 | GE Refrigerators
I have a side by side Kenmore Model # 50522101. We came home and it wasn't working. There was clicking sound from underneath so I removed the back cover and the compressor would come on and run for...
This sounds like the relay has gone on the compressor. Call your local appliance parts store
(no model no. needed) and ask for a hard start kit. Instructions are on kit.
I use ERP 410 powerstart relay capacitor and over load. See it has everything and is much better than the original.
Remove the back cover, pull the original relay off the compressor pins, cut the two wires and install according to instructions. Very easy job.
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED
Aug 02, 2011 | Kenmore Side by Side Refrigerator
Hello, I have the stainless steel bottom freezer refrigerator model GFSS6KIXASS. I purchased it 3yrs ago. This morning I noticed that the freezer wasn't working properly. Everything in there was frozen...
A.C.; Can you tell if the fan is operating? If not that could cause the problem, but it is most likely in the defrost system: this might help you troubleshoot which component is bad:
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 16, 2011 | GE Refrigerators
We have a GE Side by Side Profile refrigerator and the freezer, at it's highest setting, can't keep ice cream frozen and the ice maker only puts out about 8-10 dumps in a 24 hour period. The model is...
Sounds like your coils are dirty which will cause inadequate cooling due to reduced heat exchange at the coils. Also check to make sure fan is running (next to compressor and should be running when compressor runs). The fact that your ice maker makes ice at all suggests that compressor runs, therefor no freon problems. Problem should be easily fixed with correct diagnosis. Hope this helps.
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrigerator not cold fan working but compressor never turns on GE model gts22ibmbrww/i cleaned coils and fan blades/fan stops blowing if i turn dial to zero
Dec 18, 2009 | GE Refrigerators
Freezer frosts up and stops cooling after approximately 2 weeks
With your new timer in hand look and find a slotted screw driver head that you can turn. That is to manually advance the timer. Now put the new one in and advance it to engage the compressor and fan. Might be in the middle of defrost mode. Your unit goes through 3 defrost modes in a 24 hour period. And each mode last for 20 minutes. Once you do this I could help further if that was the case. Okay ken
May 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX24PRXBWW GE Profile Refrigerator - energy use?
I dont know how to locate these specs for you, modern refrigerators are much more efficient for a couple of reasons. Most new units have a Computer that controls the defrost cycle whereas older units have timers that defrost every 8 hours of on comp run time regardless of whether it needs defrosting. The new ADC (adaptive defrost control) can better monitor the frost on the coils to defrost less (in the defrost cycle it consumes 5x as many watts as when its cooling. Also most new refrigs, especially new GE units have much more efficient fan motors now also, however they too are computer controlled and when they fail they are expensive. Also the very high end new Counter depth models (in the $2500+ range) have a new variable speed compressor. This gives the compressor the ability to run at a low, med, and high speed, reducing even more the watts that will be drawn in normal operation when the fan motors are on low and the compressor too. If you have any other questions let me know ill be glad to advise.
P.S. Buy an extended warranty with any new appliance you purchase! Trust me!
Dec 05, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
