Acer aspire 5920 power failure - Computers & Internet
  • 32,281 Answers
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Nov 04, 2012
  • 111 Answers
SOURCE: Acer Aspire 5920 realtek sound driver
http://support.acer-euro.com/drivers/notebook/as_5920.html
Select your operating system
Check your OS by right clicking on my computer and go to properties
It should be up the top e.g. Microsoft XP Professional
You might be selecting Vista 32 instead of 64
Hope this helped you out
Blazamane.
Posted on Jan 07, 2009
e-Guru
  • 3917 Answers
SOURCE: crystal eye web cam not found on aspire 5920
Acer aspire has inbuilt web camera and therefore will work only if the correct drivers are installed. Please uninstall the drivers first from control/panel/add remove programs. Next reboot the system and then go ahead with the installation.
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
Thank You for using Fixya.com
Posted on Jul 26, 2009
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
  • 956 Answers
SOURCE: Where is the power reset on my Acer Aspire 5920?
reset button on acer aspire 5920 » Gadgets Manual
All you have to do future, enter question or specs in to google search, wealth of info to surf.
Happy surfing.
Posted on Nov 14, 2009
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
No power and the adaptor etc. is working okay
if the battery is old it may need to be replaced
have the voltage checked on that first
Jul 30, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not power on at all. The
Just to make sure:
1. With battery alone in notebook, and no power cable, do you get power?
2. With the battery taken out, and power cable plugged in, you do get power?
IF YES to the above two questions
... and u can get power using the power cable but not using the battery, then your battery is dead and u need a new one.
Mar 16, 2010 | Acer Aspire 5920-6727 Notebook
Happy surfing.
Nov 14, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Crystal eye web cam not found on aspire 5920
Jul 26, 2009 | Acer Aspire 5920-6727 Notebook
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Does my acer aspire 5920 have voice recognition
no the laptop doesnt. but vista has! rabish not very good but I'd recommend the software Dragon for voice recongnition
Mar 24, 2009 | Acer Aspire 5920-6727 Notebook
DRIVER SET OF ACER-ASPIRE 5920
Download it here http://support.acer-euro.com/drivers/notebook/as_5920.html
Mar 22, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
