Question about Dishwashers
Portable maytag dishwater leak...older model
I have an older model Maytag portable dishwasher which seems to leak water from the front. What are some suggestions you may have to fix or troubleshoot the dishwasher?
    President:
  • 373 Answers
This link should help you out.check for the column "dishwasher water leak".
click here
will wait for your comments.please do rate my solution if liked.thank you.
Posted on Jan 04, 2009
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
Older model dishwasher doesn't drain at the begin of cycle or turn on water.The timer seems to work all the way through turning off and on at each function and the fan seems to work alright.
Hello, welcome to FixYa. I understand you have a Maytag dishwasher based on your post, correct ? If so could you post a reply with the model number of this machine and I'll see what I can find for you. There were some recalls on Maytag units a while back, but I don't want to speculate...it's better to wait for the model number, in fact a serial number as well would be even more beneficial. I look forward to your reply and assisting you going forward. I hope you can appreciate there are many scenarios even within the "Maytag" brand. Thank you. Regards, Macmarkus :)
Sep 24, 2011 | Maytag Dishwashers
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water isn't coming in to my dishwater
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
May 28, 2009 | Maytag MDB9600A Jetclean II Built-in...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag PDB3600AWE leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 11, 2008 | Maytag PDB3600A Built-in Dishwasher
Dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
May 04, 2007 | Maytag 24 in. MDB7751AWS Stainless Steel...
Dishwashers Logo
354 people viewed this question
Top Dishwashers Experts
