Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
My new frigidaire freezer digital display flashes off please help
Flashes off tried up and down unlock also no luck sure i am probably doing wrong please help
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Posted on Nov 05, 2012
  • k dale
    k dale Apr 10, 2014
    Frigidaire said to quickly press the down button 3 times and then press the up button twice. This worked perfectly.
SOURCE:
Moved, freezer wont run properly, food thawed out, digital readout display flashes E and then flashes #9 alternately. what do I do?
E9 is a defective Temperature Control
  • You will need to replace Part # 297216004 It should be mounted on the evaporator behind the panel in the inside of the freezer.
  • I am including a picture and a link, it should be #21 on the diagram.
  • You have to unscrew the Knob and the 3 screws holding the temperature control Cover and the one holding the probe/sensor (#24 on diagram)
Best of Luck,
JP
http www searspartsdirect com model part FFU14K0DW0 1428 0142000 R0405108...
Jul 08, 2015 | Frigidaire 14.1 cu. ft. Upright Freezer...
Let's try this again. My frigidaire freezer model Lffh21f7hwg, the display board reads "of". How do I reset it. I do not have the owners manual.
I appreciate your post, Clayton!
From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
Mar 31, 2015 | Frigidaire Freezers
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
What temperture should i set my frigidaire digital display freezer to
Good Afternoon Friend,
I understand that you want to know the temperature to set your Frigidaire freezer. Recommended factory default setting is 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your Frigidaire status has changed successfully. If more troubleshooting is needed, please leave me your model number in your comment. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer display flashing of and ff. I can't get it to do anything else.
Hello Aaron, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Nov 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
5,777 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
