Question about Dryers
Samsung dryer loud noise
Loud noise coming from dryer when running
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Could you please describe the problem you are having a little better?
Posted on Nov 04, 2012
5 Suggested Answers
  • 76 Answers
SOURCE: loud noise when dryer runs
I agree with the reply where it could be a bearing or the belt tensioner pulley. Although typically the rear bearing will make a squealing or squeaking sound. There isn't too much that can cause noise in the drum itself. I have seen dryers where the belt was frayed or about to go make the noise you describe. I don't think it is the rear bearing, but the front glides, or bearings could be going out causing the dryer to run unbalanced.
Posted on Sep 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: Dryer makes loud noise
Probably a bad set of glides.
ea82af1.jpgor worse.Check out my BLOG on this
Posted on May 20, 2009
  • 254 Answers
SOURCE: loud noise while running
you are gonna have to get inside the unit to determine whats defective...
if you want a parts breakdown i would recomend going to sears. com clicking on the section parts and service usually upper right corner, then click parts, u should be in their parts direct section enter you model number which u can find when u open ur dryer door their should be a sticker or tag somewhere that will list it.. find ur model or sometin similiar uually last digits designate color so it doesnt matter. you can see how the unit comes apart or get prices or part numbers on specific parts.
I would personally check the operation for defectiveness on your belt,rollers, idler pully, and possibly a seal if yor dryer has sometype of glides or seal.. hope this helps
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: New house had dryer outlet
You still do not have one of the wires hooked up right...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Feb 01, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Loud noise when the dryer turns on
Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
Jan 08, 2014 | Samsung DV448AEE Electric Dryer
Loud noise coming from dryer when clothes are added
-Every thing are worn out. The tumble is not round any more, seal is loose so any loose thing or seal hit a bump. It will make sound.
This is normal for old dryer.
Mai
Dec 07, 2013 | Samsung Dryers
Samsung dryer loud rumble coming from the back
Most likely it is rollers or idler problem and need be replaced
Dec 07, 2013 | Dryers
New house had dryer outlet that electrician installed a Range outlet ( 30 amp breaker) by mistake on the wall. I changed my cord on Samsung dryer to match the outlet and dryer made a loud noise and would...
heatman101
Feb 01, 2011 | Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
The problem I am having with my Amana model NED7800AYW makes a loud noise when running
Without knowing what you mean by "a loud noise", I am going to say it sounds like the blower wheel has come loose and might need replaced.
Mar 30, 2010 | Amana NDE7800AY Electric Dryer
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Is this a good dryer?
I bought this dryer from Lowe's May '08. No problems until today. Made a loud squeeking noise at first, now more of a ball bearing-grinding noise. Service man coming out tomorrow morning. Out of warranty, of course, paid $900.00 and not even 2 years old.
Feb 11, 2010 | Samsung DV337 Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
