Won't final spin ?
Washes as normal but won't do final spin, it just keeps turning at normal not spin speed and goes on longer than it normally does,then when it stops the final spin light is flashing and clothes still wet.( filter is clear)
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
aborcass
  • 2651 Answers
SOURCE: Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Posted on Feb 22, 2008
Junoon007
  • 1011 Answers
SOURCE: Admiral Washing Machine (Model LNC6760B71)- clothes remain damp
Sir,
The motor on this washer turn one way to wash and the other way to spin and drain.
So if the washer is spinning and not draining you have a pump problem.Take the front panel off and watch to see what is happening.
You will have to check for power to the motor in spin. Either the motor is bad or the timer or both. Refer to the schematic for this.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 25, 2008
gittos73
  • 244 Answers
SOURCE: drum speed slow on final spin
what waher is this and what speed is it
Posted on Dec 07, 2008
  • 13 Answers
SOURCE: My clothes are wet after
check the brushes on you motor
Posted on May 12, 2011
Macmarkus
  • 2605 Answers
SOURCE: f21keeps flashing.clothes won't spin.f21 still flashing on all cycles.
Hello again Chris,
Thank you for replying with the model number. It sounds like the pump may have become clogged in the washer pump filter.
I would first suggest you have a look at the pump yourself unless you don`t feel comfortable doing so, then calling a service tech might be the best avenue.
Here`s how to inspect it...yours may differ slightly, but if it is indeed a bosch clasixx6 1200...these instructions will apply.
1) **Turn off the power or unplug the cord from the dryer or wall...whichever applies to your set-up...safety first**
2) Water removal...remove toe panel. There you will find a small hose with a plug in the end for draining the pump.
3) Now bleed pump drain...A shallow pan is handy for this step.
3) remove pump filter, but be careful if you don't have a shop-vac or a shallow pan and towels you may get wet...
*Once you`ve reached this point you may have trouble removing the filter if it is really plugged up with debris. You might have to wiggle it back and forth as you twist and pull.
4) When you get the filter out, visually inspect inside the pump thoroughly with a flashlight and clean it out really well. It won`t take much to prevent these from draining. i.e. a penny, hair pin, buttons etc.
Let me know if you found anything in the pump and how you make out after that.
If you removed any obstruction, simply reassemble the unit making sure the filter is screwed in tight, unplug the unit for approx. 20 mins (you may have accomplished this in the time allowed to clean the pump so it may sound redundant, omit if so) run a quick rinse cycle to test for leaks before putting the toe panel back on and you should be good to go...save for any leaks.
There are other possible factors like a pump motor, that can prevent the unit from draining or spinning out items properly, but we`ll cross that bridge when and if we get there.
Thank you for choosing FixYa, keep me posted on your situation.
Regards,
Macmarkus :)
Posted on Oct 25, 2011
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Machine will not spin
If the machine washes but won't go into the high speed spin, then either the speed control board is bad or the door switch is bad. Look in the machine there is a tech document to help you with this problem.
Nov 03, 2012 | GE WPXH214A Front Load Washer
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont final spin
sorry have not come across that model its not within my expertise
Nov 14, 2011 | Washing Machines
Washes but won't spin or drain
check the safety switch on the door of the machine, if its not working the washer won't go into the spin cycle , if you need help in checking it, or how to,, feel free to contact me back by replying to this amswer
Jun 16, 2011 | Whirlpool Washing Machines
Samsungj1045 washes but won't spin out past 7
Try this, unload the washer and put it into spin manually. If it spins for the whole cycle then it is your motor over heating, with the load.
May 07, 2011 | Samsung Washing Machines
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
