Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
It keeps saying paper jam then please wait keeps blinking
  • llsteev01 Mar 31, 2009
    Same f-n problem just got my replacement head. Pluged it in and it says paper jam. Even thought I have not even put paper in it. Push the ok butten even waited two hours it still says please wait. unpluged it, put paper in it. same thing. I looked over the back upside down forward even sideways ther is no paper jam! I am very disatisfied with kodak. It is a piece of ----
  • Anonymous Apr 10, 2009
  • 2,976 Answers
Did you check in the back where the multiplexer goes? The paper turns around the drive rollers back here and can jam up. If you didn't notice a full sheet missing, you probably just need to pull the rear cover off and clean it out a little bit. Totally unplug the printer too, it should clear any error codes that just turning it off won't.
Posted on Jan 04, 2009
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Paper light keeps blinking and can not print
This usually means a paper jam or carriage jam. Do a visual check to make sure there is not any paper stuck in the printer.
You might want to reset the printer but unplugging it from the wall and then waiting 30-45 seconds and plug it back in.
Have a great day.
Jan 21, 2010 | Brother Office Equipment & Supplies
Keeps blinking E3
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Issue: ERROR LED: E, 3
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Apr 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Printer says paper jam then please wait. Then it will not do anyt
well! the machine says that there is some paper in the machine, start by taking different itrems out such as the paper tray, look in the doc feeder and so on, good kuck
Feb 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Mfc 210c
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Jan 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jam with error
Mine did the same thing. Shut off the printer and reboot the computer. Thas all I had to do to clear the error.
Jan 04, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
194 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
