Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
My new frigidaire freezer the digital display on outside of door flashes off what to do?
New freezer the display on door just flashes off tried pushing up down .also tried to use unlock on display like it said inside door. no luck it seems alright i probably do not know what i am doing. can you help?
  • Anonymous Mar 23, 2014
    -f- is displayed on screen display on my freezer door
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Posted on Nov 05, 2012
  • 311 Answers
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
ngfam1
  • 639 Answers
SOURCE: upright freezer problems
Hi Robert,
Happy to help.
Sounds like it is low on freon
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
  • 109 Answers
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Posted on Aug 23, 2009
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
woodchuck789
  • 4059 Answers
SOURCE: I have 16.7 upright Frigidaire Ultrafreeze
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 24, 2009
Testimonial: "This advice seems really clear-- and I will get help from my hubby to implement it. Thanks a lot for your help! Anne"
mrfixit3667
  • 262 Answers
SOURCE: Frigidaire upright--
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Posted on Jan 11, 2010
Fridgeaire upright freezer no serial numbers to be found anywhere was trying to adjust temp on front of door outside now unit says of and is not running how to turn back on???
tough one
i guess its a frost free
turn the thermostat adjustment to on /highest temp temp ...then off /lowest
till the compressor kicks in
if not suspect faulty digital display panel or thermostat itself
agreed no serial number etc
makes it very hard to help you fix this
http://kitchen.manualsonline.com/manuals/mfg/frigidaire/frigidaire_freezer_product_list.html
Oct 11, 2016 | Frigidaire Freezers
Freezer door has mosture on the outside
You need to order and replace the door gasket. Also check and be sure there the hight adjustment is correct, meaning the door is centered on the opening and not off set to where it can seal.hope this helps
Aug 10, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer digital display flashes off please help
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
Frigidaire FREEZER LffH2067DW3 stuck in defrost
Turn the unit off by the circuit breaker for about 10 minutes and retry the unit again.
Jul 23, 2012 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Mar 20, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer wont shut off and goes to -10f regardless the thermostat setting thermostat is on the outside door(digital)
I'd say the freezer thermostat is stuck closed. You will have to verify this with a meter. The wiring diagram is on the back of most freezers. Good luck.
Jul 13, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
1,137 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
