Question about Electrical Supplies
I need a NGK spark plug for my PRO FORCE 106000 Generator
Original plug from MFG is LD F5TC - want to replace with a NGK plug
  • Ed Bilman Nov 06, 2012
    NGK plug or other MFG for this generator.
    President:
  • 643 Answers
NGK - BP5ES
Champion - N11YC
Autolite - 64
Bosch - WR8DC
Denco - W16EXU
Torch _ F5TC
Posted on Nov 06, 2012
Testimonial: "Thanks. The guy at the auto parts store sold me a NGK - BPR5ES. I thought this might not be the correct replacement. I will return it. "
3 Suggested Answers
  • 2692 Answers
SOURCE: SPARK PLUG GAP NGK BPR5E PLUG
Fix Ya?
Posted on Jan 12, 2009
  • 615 Answers
SOURCE: I Have a pro force 6000 that has no spark at the
First check and see if you have any cracks on the cable then replace the sparkplug with new one but make sure that the setting the correct one…before you do this you may try a test but you must be very careful…No kids around, clear place outdoors, etc .
After checking, the cables unscrew the sparkplug and put very small amount of gas in then put back the sparkplug “the same one” and see if you get a sound as backfire if yes that mean it is working good. That should take care of it…let me know and again be very careful and not too much gas
Posted on Sep 14, 2009
What size/type socket do I need to remove spark plug on my Ryobi 2300 generator. I've tried 1/2 thru 13/16 and none fit.
i cross referenced the spark plug (LD A7RTC)
and got the NGK equivalent:
SKU: #CR7HS
ITEM : # NGK7223
BRAND : NGK
Then got the specs off the NGK site
NGK 7223 CR7HS Nickel Spark Plug
It should be a 5/8" (16mm) spark plug socket.
Apr 08, 2018 | Cars & Trucks
Ngk spark plugs gap chart
In your owners manual
Maybe under the hood on label
On all parts & plug mfg sites
They come gaped
NGK shows .052 I found it,need to use the internet better
Aug 17, 2014 | 2005 Mazda 3
Ngk spark plug gap chart
usually around .028" - .032"..
n
g
k
r = resistor
b=thread size = 14mm
z
7 = heat range - NGK, the lower the number the hotter the plug. Other mfg. are opposite - higher number=hotter
h = thread length =1/2"
s
-10
These are THE important ones... the rest are mfg. specifics
May 25, 2014 | Mercury Boating
I need to find out what the proper spark plug is for a coleman 1850 genberator
Ken, The CM04143N originally comesw with a Chinese spark plug, LD E6TC. If you convert this to U.S. available plugs it is, Champion L92YC--AC 43FS--NGK BP6HS--Autolite 274 or Bosch W6BC
Feb 02, 2014 | Powermate COLEMAN CM04143N 1850W 2.4HP...
2008 Honda XL 700 V Transalp spark plug cap
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day. Honda XL700 Transalp NGK Spark Plugs NGK honda xl700 transalp MSA Direct
Thread ngk spark plug cap sparks outside xl700
Honda Transalp XL700V Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda XL700V Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 03, 2011 | 2008 Honda XL 700 V Transalp
What type/size sparkplug should I use in my ef2500 yamaha gas generator?
The Yamaha EF2500 portable generator uses a NGK spark plug #BPR6HS. Just bought on this week at the local NAPA store to replace the old spark plug in my generator.
Tom in Lafayette, IN
Nov 12, 2010 | Garden
I what to change my spark plugs for my 1997 honda passport
Visit your local parts store and purchase a set of ND or NGK plugs. DO NOT let them talk you into platinum plugs, "triple fire" plugs, Bosch, or anything else! Japanese plugs are made to a different standard than others, and anything other than ND or NGK will not give you top performance or mileage. To do the change, you'll need a 3/8-inch socket wrench and a spark plug socket. You do NOT need a torque wrench. Back the plugs out one at a time, and replace each one before moving on to the next. . Note the resistance when you back the plugs off, and tighten each with the approximate force that it took to remove them. If your plug wires are original you might want to replace them as well. Try to get a set of Japanese wires, but good quality American wires will do. Be sure to replace/connect the wires one at a time so you don't cross-connect anything.
Jan 12, 2010 | 1997 Honda Passport
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Electrical Supplies Logo
294 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
