Question about Crosley CR248 Turntable
Crosley cr2405c recording problems
When trying to record onto a cd I am getting 3 tracks in one song instead of the song being in one track
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 1894 Answers
SOURCE: crosley cr249
then the recording head is facing the problems sir.
amy be small loose connection in the circuit.
if u r expert in electronics u can fix it easily
Posted on Jun 19, 2008
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
  • 11800 Answers
SOURCE: My unit is a Crosley
If all the mechanics appear in order then the fault is in the preamplifier or its power source - check all the components and the voltage. Also you could add extra capacitors to better filter the power - the "warbling" might be the ripple from the power source.
Posted on Aug 29, 2010
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Owner Manual
http://crosleydirectdpd.com/product-documents/CR246_Manual.pdf
Dec 09, 2013 | Crosley CR2405C-PA Director 3 Speed...
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Trying to wright some tracks in song mode to cd so i could listen in the car but it will not let me. Any suggestions?
I have a similar Yamaha that makes me re-record the 16 tracks of the song onto the stereo track (left and right) then save. See if under the record setting if it has an option to "record to stereo track" or something similar. Hope that helps.
Dec 16, 2010 | Roland Mv8800 Production Studio
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
When I record a vinyl album on a CD it all winds up on one track.
Pause each song for every recording to separate the tracks.
Feb 23, 2009 | Denon CDR-W1500 2-Disc CD Recorder
How do get multiple tracks when djing
press the next botton on the recorder every time u switch songs djin".
Dec 28, 2008 | Philips CDR775 2-Disc CD Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Crosley CR248 Turntable Logo
403 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
