Question about Watches
How do i remove the battery from a fila sports watch
NEED TO REPLACE BATTERY BUT UNABLE TO REMOVE OLD ONE
SOURCE: flashing display
I just had this problem. Put it to the chronograph, pull out the crown to the 3rd position, press the A+B buttons at the same time until everything on the display comes on.
Push the crown back in and the watch will be totally reset. Should be fine after that.
Posted on Dec 19, 2007
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
  • 2501 Answers
SOURCE: unable to remove back of watch to replace battery.
Battery replacement is more difficult than it appears. One of the most common problems is watches that do not work after battery replacement.
Take it to a watch shop and ask them to do it for you.
Posted on Feb 06, 2010
  • 8404 Answers
SOURCE: What tools do i need to remove back cover to
sharp knife.
Posted on Mar 18, 2010
Need help changing battery for my guess watch G85635L..tytyty
  • Remove back
  • Find battery. Identify type and note mounting arrangement for later installation
  • Obtain new battery
  • Remove old battery. Install new one correctly
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery for you.
Nov 28, 2016 | Guess Watches
What exact battery do I need for Seiko SKA348?
  • Remove back
  • Find battery holder
  • Note battery type
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your Seiko watch to a jeweler who, for a reasonable sum, will replace the battery
ORORO
Nov 22, 2016 | Seiko Watches
Need to program a fila silverstone watch
I have a copy of the book for it.
Jan 03, 2012 | Fila Watches
Just had a new battery installed in a fila wind master watch. the hr, min and sec hands are spinning and it goes through the start cycle. not able to stop this. also need instructions on how to set time....
Hi, According to your problem first make sure that the battery that you have changed is OK, or try another battery. Your watch need a factory reset. If normal factory reseting doesn't solve your problem then you have to repair the machine.
Jun 29, 2011 | Fila Watches
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
Remove the back, to replace the battery
You need either a caseback knife or caseback wrench depending on whether it's a screwdown or snap-on back. If it's a snap-on, you'll also need a caseback presser to put it back on. Using the wrong tools can easily cause damage to your watch. If the watch is "water-resistant" be sure to replace the gasket as well or it will leak - you cannot reuse the gasket. You best bet to do this without having to buy tools, find the correct battery and gasket and risking scratching the watch is to let a watch shop or jeweler do it. Most places will charge about $8 to replace the battery and gasket. Sears sometimes charges only $4 so either way it's worth it. Even though I have the tools myself I usually bring my watches in and have it done since I'd have to go out and buy the battery & gasket anyway.
Apr 23, 2010 | Columbia All Sport Digital watch
How do I get the old battery out?
Very risky to do by yourself without the proper tools. If you don't want to spend the 6 to 12 dollars to have the battery changed by a professional you will likely need to remove the strap by disconnecting the pins and then screw off, unscrew screws, or pop off the back with a sharp knife. You can now replace the battery and put back together.
Oct 17, 2009 | Timex Marathon Sports 59071 Wrist Watch
Fossil Kaleido Watch LI22248 replacement batteries???
Depending on the age of the watch it could have a ECR series battery over the top of the 377 powering the movement or it could have 2 377's in the circuit board over 1 377 in the movement.
I always recommend taking Fossil watches to a certified repair shop that can re-seal the watch so you dont void your 12 year warranty and the watch remains water resistant and resistant to small particles.
Sep 01, 2009 | Fossil Sport Auburn University LI2248...
For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
May 11, 2009 | Casio F91W-1 Wrist Watch
Battery change on Columbia All Sport CL 5008
Buy a set of precision srewdrivers. Remove back(4 screws),take your 1 mm flat screwdriver and push straight down at the end of the hold down strap at the inside end. KEEP IT TIGHT IN THE NYLON CATCH! The hold down is hooked on the bottom of it. It will release and you will be able to lift that end and replace the battery. Then just push it back to hook it,VOILA! R.J.S.
Mar 16, 2009 | Columbia All Sport Digital watch
Watches Logo
186 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
